Old 02-22-2013, 06:59 PM
Terrybrd Terrybrd is offline
Default Rivet gun
On the pulled rivets for the RV-12, is the nose of the rivet gun flat or concave?
I bought tools from a friend that built a Zenith 601 and his was concave so I just want to be sure that I use the correct one.
So far I haven't seen anything that tells me in the instructions, but I'm still unpacking the 1st kit and doing inventory.
Terry
Old 02-22-2013, 07:14 PM
YellowJacket RV9 YellowJacket RV9 is offline
I'm sure you'll get more advice from a 12 builder soon, but I believe the zenith is built with Avex rivets which use a special rivet puller with a concave nose that forms the rivet head. I don't believe the 12 uses these so a basic handheld or pneumatic rivet puller is what you will want.
Chris
Chris Johnson
Old 02-22-2013, 07:43 PM
rgmwa rgmwa is offline
Common flat handheld or pneumatic rivet puller is what you want.
rgmwa
RV-12LR 912ULS
120346
Old 02-22-2013, 08:17 PM
aallard aallard is offline
My rivet pullers (hand and pneumatic) are both flat.
Adam Allard
N116AA RV-12 #722 (under construction now)
aallard@yahoo.com
Old 02-22-2013, 09:16 PM
I used a Harbor Freight pneumatic puller with a flat gripper face.
Old 02-23-2013, 04:54 PM
JoeM's Avatar
JoeM JoeM is offline
Default Replace the tip
You shouldn't need a new puller, you can just replace the tip.
Joe Mikus
MSgt USAF Ret Avionics Tech
Perryville, MD
Student Sport Pilot
Future RV-12 Builder?
Old 02-23-2013, 05:02 PM
Thanks for the info.
I have another puller with the flat face so I'm all set.
Started some parts today and soon ready to start pulling!!
Terry
Old 02-23-2013, 05:07 PM
Mel's Avatar
Mel Mel is offline
Zenith provides flush rivets with their kit and has you modify the puller to form the rivet into a "domed" head rivet.
If the head is modified correctly, it should fit a standard dome head rivet. Try a couple on scrap. It will likely work fine.
When I built a CH-601HDS, I flush riveted the entire airplane. So I never modified the puller head.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
