02-15-2013, 07:13 AM
I think I like the idea of mounting it Aft of the firewall more and more. Two less connections getting fatigued, some chance of spotting a fuel leak (at least a major one), one less hose. 4 less FWF connections to leak, less clutter, etc.
I will say IF the unit is affected by the electric pump (I'm carbed, with the pump on the firewall, so I don't think it would be) you'll want to calibrate it whenever way indicates LOWER fuel flow (pump on or off), so you're always conservative with quantity remaining.
Macon, GA (KMCN)
RV-7, Niner Fife Victor
02-15-2013, 09:03 AM
Flow around bends
The reason I placed my cube away from the FW connection was due to the sweep of the tubing. I read somewhere in the installation to be careful of turns on the fuel line near the red cube. Placing it just foward of the existing fuel pump doghouse gave the least amount of curves near the cube.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
02-16-2013, 12:24 AM
I also mounted mine in the tunnel.
Usually, when I opened the canopy, I would smell the leather seats. After 6 months of flying, that smell was replaced by a very faint smell of avgas.
I finally spotted a blue stain under the red cube, and it appeared that I had forgotten to use fuelube on the fitting... Oops, but easy to fix.
Would I put the red cube in the tunnel again? Yes, the leak I had would probably stay unnoticed for months if the red cube would be forward of the firewall. I does create an extra point of failure inside the cabin, but any failure would be noticed much earlier.
02-16-2013, 12:14 PM
Here is what I am thinking of doing - connecting the red cube to my electric fuel pump with a nipple. My other option is to put it closer to the rudder, but I don't want it to be in the way of my feet. Any thoughts or suggestions ?
[IMG]  [/IMG]
Option one
Option two
02-18-2013, 08:56 AM
When mounting the red cube in the RV-7A tunnel, is it necessary to make a physical connection of the cube to the fuselage floor, or will the 3/8 fuel tubing provide a stiff enough mount? I have 1/8" foam insulation on the floor and the cube sits on top of the thin foam. It seems pretty rigid this way, but I am curious about the experts opinions.
Bob B
RV-7A Sold
RV-4 Sold
DFW TX
Dues Paid
02-18-2013, 09:06 AM
Don't use fuel lube or you will be doing the job again soon
There are others but this one works pretty good.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
02-18-2013, 09:21 AM
Downstream or upstream of the electric pump?
I am about to start this installation in my RV-6. My facet electric is mounted on the firewall. I thought about installing the fuel meter in the fuselage upstream of the electric. Between the selector and the electric.
Will this work?
Kyle Gee
Purchased and sold flying RV-6
RV-7 Kit (sold to purchase C150 to train my kids)
Purchased flying RV-7
04-08-2013, 06:45 PM
This look OK for red cube mounting in tunnel?
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
04-09-2013, 10:51 AM
Originally Posted by RV10Rob
Even if you do plan to use it to measure total fuel consumption, it isn't a problem. The error is small enough (at least on the RV-10) and the electric pump runs so infrequently that the net effect on the fuel consumption data is inconsequential.
I'm working through this issue right now. I have my floscan after the fuel selector and before the boost pump. Rob's point is probably correct for times when you're flying cross-country with the fuel pump off the vast majority of the time. However, if you mix in any time doing pattern work, where the pump is always on, your totalizer will likely be significantly off the next time you do a fill up. In my case, my fuel flow will read about 2gph higher with the pump on then when the pump is off.
Also, while the transducers come with a default or preliminary k-factor to program into your EFIS, you still have to adjust/calibrate it for your particular installation. It's hard to figure out a new, more correct k-factor if at any point the boost pump was on between fill-ups. The point I'm trying to get at is if you do not do this calibration and do it accurately, your EFIS will not necessarily be showing actual fuel flow even when the fuel pump is off.
The good news is that if you try to calibrate the k-factor for a tank of gas in which the pump was on at any time, your totalizer will error on the conservative side (read less than what you really have).
In retrospect, I would have put my floscan forward of the firewall. Anyway, just some things to think about.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
04-09-2013, 12:24 PM
I can't comment on the applicability in a RV-7, but in the RV-10, the red cube was intended to be mounted on VA-188, which raises the cube about a 1/4" off the tunnel floor. This would be a more secure method if there is room for the mount in the RV-7.
