02-11-2013, 07:54 PM
My 1955 Cessna 180 has one of the three-conductor plugs, and I've never used it. I've owned the plane since 1986 and have about 1,400 hours in it, mostly cross-country.
It would be high on my list of things to remove to save a bit of weight, complexity and room under the cowl.
If the battery is reasonably accessible, consider that jumper cables or a battery charger might also be available at airports.
Dave
02-11-2013, 08:12 PM
I knew I saw this!!!
Here is a really cool alternative to any expensive plugs. Good for charging, but not cranking. I would not want to get airborne on a really dead battery anyway.
http://www.eaavideo.org/video.aspx?v=1009394733001
CC
David Boeshaar
RV-9A - N18TD (reserved) - Fuselage.
"My greatest fear: What if the hokey pokey really IS what its all about?"
TDAircraft.com
-July-
02-11-2013, 08:29 PM
Dave
I installed the ground power plug for two main reasons:
1) While building I've already used it for many hours of avionics/electrical systems testing and configuration using one of these:
2) I live in Minnesota, and even with quarter-turn fasteners attaching the cowl, the battery is not that accessible. I want to be able to quickly jump the aircraft to get the airplane started to get it somewhere warm to get the battery charged, if needed.
Somehow, living in Minnesota programs the brain to think about prioritizing the ability jump-start vehicles before frostbite sets in, even if in reality I won't use it much after I start flying
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
02-11-2013, 09:58 PM
VAF Moderator / Line Boy
Bingo! Even though I lived in Texas when I built my -8, I remembered all too well jump starting airplanes that weren't set up for it when I lived (or visited) up north. And the truth is, I travel all over the country, at all times of the year, and getting stuck someplace cold is no fun. But the most important reason was cited above - easily putting external power on the airplane for working on glass panels and avionics. I put the Piper-style plug on because it was simpler - I carry my custom jumper cable on extended trips when it might be needed.
Now on our -3, I simply didn't want the weight of the jack - I did, however, put in a low-amperage external power jack to power the ship for avionics set-up and testings. It can also easily be used to charge the battery, which is buried in the baggage area.
Bottom line - whatever you choose, do it because it makes sense for your situation, not because someone else chose it for their situation.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
02-13-2013, 10:22 AM
Reference post #10
I'm not sure I see the necessity of the groung power plug relay. My Bonanza does not have one. Please enlighten me.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
02-13-2013, 12:17 PM
For one thing, the ground power relay acts to protect your electrical system from overvoltage of the ground power supply. If the ground power supply is inadvertently set to 28VDC instead of 14VDC, the OVM-14 OV module will "crowbar" (short out) the ground power relay coil causing the ground power circuit breaker to open, preventing the ground power relay from energizing, thus preventing the 28VDC getting applied to your electrical system.
It will also protects against reverse polarity.
Paul Winkels
02-13-2013, 06:05 PM
ground plug
I have a ground plug For Sale, as I had it in my RV6A build kit and decided not to install it as I'm handy to everything where I fly.
If your interested let me know and I can email you back with the make etc..it's the round type all new and as well I have some other items that I didn't use all new as well.
aussieflyer654@gmail.com
Kind Regards
QUOTE=mmarmol;743202]Hello there,
I am currently looking into what type of ground power receptacle to put into the aircraft that I am building. The main two options are a Cessna-type three terminal plug and a Piper-type one terminal cylindrical plug.
Are there any pros-cons to each of them?
Is any one of them more/less prevalent in your average GA airport? I think this would be my deciding factor but I have only had to jump an airplane *once* and the FBO there had both plug types (it was a big jet center).
Thanks for the help guys!
~Miguel[/quote]
Aussieflyer
Donation paid for 2016
Ravin 500 completed - SOLD
RV6A QB s/n 60577 Builder -Sold
N654PT First Flight (12/22/2012)
SOLD 12/4/2015
Purchased flying RV4 N173G
Based: KPMP, Fl
02-14-2013, 12:36 AM
Thanks!
Man you guys are awesome
Looks like the answer is to install the Cessna/Military style plug on the airplane for maximum compatibility with whatever random GPU I might need to plug into in the future. And that is a great point about it being helpful to troubleshoot/test the aircraft's electrical system. Also, thanks for the wiring diagram!
Have a good one,
~Miguel
02-14-2013, 02:28 AM
EAA video - DANGER!
Originally Posted by comfortcat
Wow. I just watched this video. What it suggests is a VERY BAD IDEA!
Using an uncommon non-standard connector system (Piper plug, etc.) as we've been discussing, is one thing. The worst penalty for that is just inconvenience. No biggie. But what this video is suggesting is to use what IS a standard connector system for something entirely different, household 110V A/C, that is dangerously incompatible with 12V DC aircraft electrical systems.
Even with the male and female ends reversed, that is asking for trouble. Only a matter of time before someone with a gender-changer accidentally plugs the airplane into a wall socket, or even more easily, accidentally plugs an A/C appliance into the airplane. In either case, likely resulting in damage and possibly fire. Or worse, when someone accidentally plugs the male half of the cord into a wall socket and gets electrocuted at 110V by touching the exposed battery clamps at the other end of the cord...
And to continue... As the video shows, the guy attached battery clamps to the other end of the cord, thereby creating what looks very much like jumper cables. Hopefully even the casual observer realizes that it would be a very bad idea to try to jump-start using this contraption, putting hundreds of Amps through an extension cord designed to carry about 15 Amps. It would almost certainly catch fire. But perhaps less obvious, it would still be a very bad idea to even charge a dead battery with this thing. At the start of charging a very low battery, it may very well accept currents in the neighborhood of 50 to 100 Amps. Not quite as bad as running the starter, but still a major overload of this very unfortunate extension cord, and again, flirting with the prospect of fire.
So, if I really have to say it... folks, please don't do what this video suggests.
