Old 02-12-2013, 07:35 AM
bret's Avatar
bret bret is offline
Default Baggage floor
Did you follow the plans or did any of you add nutplates to have the floor removable, it looks like around 32 nutplates?
Old 02-12-2013, 07:58 AM
Mel's Avatar
Mel Mel is offline
I riveted mine in 1992. Removed them several years ago to install steps. Riveted them back in.
Unless you have reason to remove them often, it's not much difference to drill them out.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-12-2013, 08:10 AM
larrynew's Avatar
larrynew larrynew is offline
I did nutplates and made the floor removable as I'm planning on antennas (transponder and ADSB) under the floors. Definitely do it during construction and not after like I did.
Larry New
RV-7A - Built, flying 900+ hrs
RV-10 - Built, flying 2.9 hrs
??? - RV-12, Subsonex
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 02-12-2013, 10:06 AM
Buggsy2's Avatar
Buggsy2 Buggsy2 is offline
I made mine removable with nutplates, but only every other rivet hole.
Ralph Finch
RV-9A QB-SA
Davis, CA
Old 02-12-2013, 10:14 AM
JonJay's Avatar
JonJay JonJay is offline
The floor is structural. Probably not an issue but I would want a sign off from Van's on this due to the change in fastener spacing.
I riveted mine per plans. Never had a need to remove them.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-12-2013, 10:22 AM
randyintejas's Avatar
randyintejas randyintejas is offline
I riveted but, put an access plate in one side.
RV 7
391RK Reserved
IO360 9:5:1 AFP
Slow Build
Last 90%
Tyler, Texas
Old 02-12-2013, 11:25 AM
bret's Avatar
Hum maybe make one removable,
Old 02-12-2013, 11:34 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
I used platenuts for the entire baggage floor. I checked with Vans and they (IIRC Ken Scott specifically) said the only drawback to doing so was cost.
That said, except for the side which contains my strobe power supply, next time I would just rivet it down with the LP4's. I can't really imagine a need to get in there in the future.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 02-12-2013, 12:32 PM
I also used J Channel for a little support to the area between the ribs. helped a lot.
RV 7
391RK Reserved
IO360 9:5:1 AFP
Slow Build
Last 90%
Tyler, Texas
Old 02-12-2013, 01:13 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
I just installed a Dynon UAT on a friends RV-6A that had screwed down floorboards in the baggage area.
In this case it was easier to route four 22g wires back to the UAT box than to route another co-ax past the spar.
The UAT was simply bolted upside down to the bottom of the baggage floor - a simple solution...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
