  #11
Old 01-25-2013, 05:08 PM
APACHE 56 APACHE 56 is offline
Default My thoughts
Originally Posted by ILikePike View Post
I am nearing the end of the canopy ...
If still an option put handles on the roll bar to aid entry/egress.
On all the available sidewall spaces put pockets/bins/holders
Have your interior fabricator fashion you a tonneau cover that extends from the windscreen aft to near the canopy rail which will give you sun protection for the times when you don’t want to use the canopy cover (e.g., breakfast run).
Get the most comfortable seats regardless of cost (the phrase “pay me now or pay me later” comes to mind).
I had carpet in the front cockpit for a flight or two then removed it. The “slippery” floor has more utility for me.
One more vote for the “no armrests.”
I used Flightline Interiors which you’ll find well recommended in the “search” section.
Don Stiver
RV8 "Little Pill" N6371S, Merritt Island, Fl.
BPE IO-390, Dual P-mag, MT 3-blade, AFP system
Steen Skybolt: Sold
Old 01-25-2013, 06:49 PM
David Paule David Paule is online now
Who makes the best seats for a 8? I am thinking leather.
Try sheepskin. Cool in the summer, warm in the winter, luxurious - and not slippery - any time.
Dave
Old 01-27-2013, 09:30 AM
Torch76 Torch76 is offline
Default Cost
Dave
I haven't seen a whole lot of pricing information on sheepskin. How much does it typically run? And from whom?
John
RV-8 Emp
Old 01-27-2013, 10:23 AM
rodeja rodeja is offline
I am nearing the end of the canopy and need to make some decisions about the cockpit. I am planning to keep interior simple with nice learher seats and arm rest pads. In general terms, what would you do again and what would you change if you had it to do over again? Things like seat choices, switch and control locations, fresh air vents, interior lighting, etc.
If I had to do it over again - would not get the full leather side panels (Classic Interiors) again. They take up too much room in our 9 as nice as they are. Wife and I are not big, but not small either, so I guess that is relative. The tonnouea cover is awesome - keeps everything out of the sun and sight. On that note, would probably get the heated seats option next time.
Would not use the junk fresh air vents from Vans - they leak big time and in our weather (Alberta) are more than annoying. Will be updating that this spring.
Would not be without our Reiff pre-heaters. Have the cylinder bands, 2 oil sump and 1 oil cooler heaters - 1.5 hr plugged in and oil temp is 70 - 85 before startup. Unheated hangar and about 20 outside.
Two changes on the sticks switch - I would like the flap control on the stick and a PTT on the passenger side as well. No big deal - we bought it built, unpainted, no interior and couldn't be happier. (Thanks Troy )
Ron J
RV9 - Bought & Sold
160 HP 0-320
#90899
C-FTJE
Restoring a '47 Luscombe
Old 01-27-2013, 11:54 AM
I'd expect that most if not all upholsterers would have it available. Flightline Interiors does and not only has a great reputation, they made the most comfortable seats I've ever sat in.
But I can't say what the difference in cost is. Shouldn't be too much, though.
Dave
Old 01-28-2013, 06:57 AM
flyenforfun's Avatar
flyenforfun flyenforfun is offline
Our seats are ultraleather sportsman seats from Classic Aero Designs. Wouldn't change a thing about those.
I don't have any arm rests and haven't yet felt a need, I don't even think my elbows will reach that area in the front or back.
A stick boot setup for the rear is on my list of things to buy because I am getting a ton of cold air from that area in the winter.
Non skid on the floor is also on my list.
My rear passenger headphone jacks are all the way in the back rear behind where their elbow would be in the "arm rest". Turned out to be a perfect location.
Matt Giordano Sr. and Jr.
RV-8 - N861MM
Wilmington, DE
Old 01-28-2013, 06:58 AM
The Van's air vents do suck, but in the winter a little tape solves that problem.
RV-8 - N861MM
Wilmington, DE
Old 01-28-2013, 07:16 AM
drill_and_buck's Avatar
drill_and_buck drill_and_buck is offline
What I like and recommend
1. 2 small eyeball fresh air vents on the panel. I bought a pair from Stein, I think they were mfg by Boeing for the F-16. Very nice and worth it.
2. Vetterman exhaust with mufflers. Each muffler has a built in heat muff that produces an abundance of heat. I placed two heater valves on the firewall, one in the middle of the floor and one plumbed to a large vent that is on the aft side of the front baggage panel. This one shoots hot air to the GIB.
3. Heated seats for sure. I often fly through the winter in the NE without a jacket.
4. Power outlet directly wired to the battery buss. This is very helpful, particularly when you want to trickle charge the battery or you need a 12v source without having to power up the master.
5. With heavy use of Foreflight and a GoPro camera I have an increase need for USB power ports that will charge an iPad and iPhone. To charge the iPad while in use you need a 2.1 amp charger. Just ordered one from Commit and it will be installed shortly.
6. Pockets to stash glasses, charts, checklists, pens, iPhone, .....
7. I had Flightline Interiors make some side panels. I would install them again in a heartbeat. Not only do they look nice but they also help keep the interior warm.
8. Music jack for iTunes, can't fly without it.
Mike Draper
RV-8 N468RV
First Flight 11/13/2011
TMX0360, Pmags, CS
Bridgewater, MA
KPYM
Old 01-28-2013, 09:50 AM
pvalovich pvalovich is offline
Default -8A Comfort
Sheepskin seat cover from Sporty's - really increases the comfort level of a "fighter-basic (no upholstry) cockpit.
Old 01-28-2013, 10:10 AM
RPorter's Avatar
RPorter RPorter is offline
My biggest fuss with the interior on our -12 is the velcro holding in the carpet near the rudder pedals, as not enough was supplied and carpet would shift and bind with the pedals. Always have to check that on pre-flight now.
Ross Porter
A&P Mechanic, Republic Airways
Indiana
First Generation Eagles Nest/Aviation Nation RV-12 Builder/Pilot
