Old 01-21-2013, 01:43 PM
Limey Limey is offline
Default Inspection/Maintenance for E-LSA
I am contemplating building an RV-12 but am a little confused by the regulations regarding the maintenance and annual inspections. Is the builder of the aircraft eligible to perform these tasks, or do you still have to go through the 16 hour training program?
Clarification would be greatly appreciated!
Old 01-21-2013, 02:17 PM
Mel's Avatar
Mel Mel is online now
Anyone can preform maintenance, modifications, etc. on Experimental Light-Sport aircraft.
To sign off the annual condition inspection, you must hold the repairman certificate (inspection) and own the aircraft.
16 hour course is required to obtain the certificate for fixed wing ELSA.
If you build as Experimental Amateur-Built, you may obtain the certificate by showing proof that you built the aircraft.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-21-2013, 04:40 PM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
And just what are the requirements for the expanding field of SLSA aircraft?
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 01-21-2013, 06:24 PM
Bill_H's Avatar
Bill_H Bill_H is offline
Answers here http://www.askbob.aero/node/286.
SLSA is almost as restrictive as any other non-experimental! The maintenance and inspection was a big reason I chose ELSA. That 16 hour course, no problem. Building the plane was the real teaching!
Old 01-21-2013, 07:42 PM
DonFromTX's Avatar
Thanks for the reference Bill, I learned from it.
Old 01-25-2013, 07:01 AM
Thanks Bill - that was a useful link. It still seems odd to me that if you build the 12 to E-AB rules you can do your own annuals, but if you stick to E-LSA rules you have to take a 16 hour course to do the same job? Seems to me that the actual work you have done, and the associated understanding of the airframe, are identical!
Old 01-25-2013, 07:17 AM
Mel's Avatar
The difference is that the 16 hr course allows you to perform the annual condition inspection on any ELSA that you own.
Also, technically, an ELSA kit can be completed up to 99% with you only completing 1% of the build.
The certificate for the EAB is good for that aircraft only.
