  #11
Old 01-17-2013, 08:59 PM
bkthomps bkthomps is offline
Penn yan is going to use it for a magazine ad photoshoot, I'll post up a pic when they send some pro shots
Old 01-18-2013, 04:54 AM
Scbado Scbado is offline
Default Wow
That is sharp!
Jerry Roeder
C150 N222PA at 02C
RV-9A Standard Build Slider
Empennage done
Left Wing built
Right Wing built
Fuselage in process
Finish kit received
Moved Project to 57C
Old 02-13-2013, 12:12 PM
The clear yellowed a bit on the cylinder heads, but we are going to fix that with another coat of white/clear mix for the cylinders.
Made 184HP and is expected to make a bit more once it is all settled in and the rings are seated better.
Old 02-13-2013, 04:31 PM
Michael White's Avatar
Originally Posted by bkthomps View Post
[IMG]
Brian,
Nice HP output! Good to know it won't be a slug...
Do you think the yellowing on the heads (obviously caused by the combustion heat) will be a persistent problem?
Moose
VAF #136
Old 02-13-2013, 05:02 PM
Originally Posted by Michael White View Post
Brian,
we will see, not a huge deal if it is but I am hopeful a top coat will solve that.
Old 02-13-2013, 07:10 PM
bird's Avatar
bird bird is offline
Nice! What kind of paint is that? I might want try painting my engine.
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 02-22-2013, 01:09 PM
it's a good day indeed!
keep pounding those rivets (or in this case, saving those pennies)
Old 03-03-2013, 08:08 AM
and this thread has come full circle now, i'll stop posting in it
