01-17-2013, 12:44 PM
Yes
Dave, your correct....70ksi failure.
It also appears to be the tailspring from van's as a few have mentioned. This weldment may have been the unlucky lemon out of thousands of tailsprings? Let's hope that that is the case.
Ed Avila
St. Johns, AZ (SJN)
N646A RV9
Worlds longest RV build...but getting there
01-17-2013, 12:45 PM
Wow, that is a very poor weld job. As an old pipline welder that was teaching me stick welding as a kid would say, "That one won't pass X-ray".
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
01-17-2013, 01:36 PM
Originally Posted by brad walton
It does look like a Bell tail wheel fork. But the swivel is probably Van's. Bell builds the forks but suggests you install it on the Van's swivel, which it fits perfectly so there is no need to redrill the assembly to the tail spring.
Maybe the title of the thread can be changed - the tailwheel fork didn't fail, Vans spring to swivel weld did. I'd hate to see Bell tailwheel forks get a bad rap on a misunderstanding.
RV-7 TU 904KM (reserved)
Construction Log
01-17-2013, 02:17 PM
Cold Weld
I can't help but to study the photos in hopes of providing some useful information to the group. Please forward these photos to the mother ship. I'm sure they would want to do some failure analysis on these components or at least be aware of the joint failure to determine preventive measures of inspecton and avoiding future occurrences.
Chuck
RV7 in Process
- Empennage Complete
- Wings and Fuel Tanks Complete
- Fuselage In Process
Dues Paid 10/16
http://mykitlog.com/cka357[/url]
01-17-2013, 02:32 PM
Tail wheel cold weld
To answer a few questions
The brand of tail wheel is what comes with the kit. I did install a Bell tail wheel but that is just an insert that fits in the original WD-101.
The penetration of the weld looks very shallow and that was from 5:00 to 8:00 and 12:00 to 1:00 the rest was not holding (to my untrained eye). So moving backwards would put the most stress on the 12:00 to 1:00 weld.
On the bright side I wasn't landing! No better place than in your own hanger for it to break. I called Vans and talked to Joe in support. He said I was describing a quality control problem and send him these pictures.
Yes I think I did get the one lemon out of a thousand tail spring kits.
Thanks every one for the support
G P
01-17-2013, 02:35 PM
Let's also note the presence of corrosion, which could have been a contributing factor.
Dave
01-17-2013, 02:44 PM
This looks like a bad weld, poor penetration, also maybe not normalized after or allowed to cool to fast. Another possibility is the wrong filler rod was used. You may want to ask the manufacturer if the welder was aircraft certified for steel.
Then again you may want to buy a replacement from someone else.
Or, even more fun, take a semester or two and learn to TIG weld at your local community college and take you aircraft certification exam. I think that is one reason why most of us have experimentals is to learn new skills.
01-17-2013, 05:29 PM
Not looking too good, broke right through the center of the weld as in weld failed, don?t see too much of this, never seen it on any RV part regardless the welder.
To be clear we don?t build the parts pictured in this thread.
01-17-2013, 05:36 PM
Poor weld and they likely used the wrong filler rod. Easy to fix.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
01-17-2013, 08:15 PM
Agreed.
All the rust doesn't help. Maybe some triangle finger stringers would provide 150% loads to hold up on excess stress.
