Old 01-17-2013, 06:43 AM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Thanks.. will look at mine next time to see what color. I was running rich at first but have gotten much better at leaning, especially leaning on the ground... what is best procedure to clean the exhaust?....ie..what should be used to do so?
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 01-17-2013, 06:57 AM
Sam Buchanan's Avatar
been here awhile
Default auto gas sooty--100LL gray
Running auto gas can produce a sooty black exhaust stack (and spark plugs). The gray residue we see is the result of lead in 100LL.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 01-17-2013, 09:05 AM
longranger's Avatar
Just run the engine in a properly leaned conditon; it'll clean itself (at least my O-300 does).
Thank you Sam! For years I've thought I'm the only one that's had problems with sooty exahust with mogas. Regardless of how agressively I leaned, the pipes looked like they were attached to a diesel.
RV-7 TU 904KM (reserved)
Construction Log
Old 01-17-2013, 09:07 AM
swixtt swixtt is offline
that is exactly correct.
RV9.... Tail done. Inspection done! Wings pre-cover MDRA inspection done. Closing them up now. Fuse underway.
