Old 01-15-2013, 09:23 AM
Clarkie Clarkie is offline
Default CFI Renewal
Any of you guys know what's involved to get my CFI renewed? I let it expire 3 years ago. I am employed by a 121 airline, but not a captain, so can't use that avenue. Thanks.
Tom Clark
RV-6 Sold
F1 Rocket
Lake Norman Airpark - 14A
Old 01-15-2013, 09:27 AM
218KR 218KR is offline
I think it would be a "reinstate", not a renewal. I believe you must take a check ride in a complex. No sign off is required. Somebody? Is this right? I'm not staring at the regs, I'm just thinking aloud.
Old 01-15-2013, 09:36 AM
DanBaier's Avatar
DanBaier DanBaier is offline
Default Probably will need a ride
Dig out the Practical Test Stds from the FAA site - the PTS for CFI tells you what is necessary for a reinstatement. Reinstatement (or addition) of any rating on the CFI is good for everything. For example, someone with ASEL CFI does a AMEL add on - makes the certificate current again. Someone with ASMEL does a ride ASEL - makes the certificate current again.
Also, see the FAA guidance at http://fsims.faa.gov/PICDetail.aspx?...25734F0076665F
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 01-15-2013, 11:37 AM
xblueh2o xblueh2o is offline
You will need to take a ride.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 01-15-2013, 12:11 PM
Chris Thomas Chris Thomas is offline
PM me. We have a guy at my airline who used to be a Fed & does CFI reinstatements. It is WORTH spending a day and jumpseating to see him.
Old 01-15-2013, 12:12 PM
DGlaeser DGlaeser is offline
I did mine about 5 years ago with a DPE. About 3 hrs of ground discussion and a trip around the pattern in a Cherokee 140. I don't recall what paperwork was involved, but I'm sure it was an 8710, which means IACRA these days. No sign off was required.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 01-15-2013, 01:48 PM
steve91t steve91t is offline
I'm in the same area, and situation. You fly for PSA? Just a thought, do you have a commercial glider rating, do you? That's what I've got and all I'm going to do is get a CFIG and that'll renew my CFI for airplane. The glider add on would be a much easier and cheaper way to do it.
Steve
