  #81
Old 01-06-2013, 07:22 PM
Originally Posted by Wayne Gillispie View Post
In this case here AP may be another option. Anything aft of pitch servo and one is left with trim, power and weight shifting(which works, we have already tried that up high).
Don't forget the flaps. They create quite a nose down pitching moment on my -6. I'd bet the -10 is similar.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
aerhed aerhed is offline
If the connection at the elevator fails, what would the autopilot be connected to???
Nothin'. It will only work if the stick comes loose. Since the servo is hung at the middle bellcrank anything loose aft of there is all on its own (except for trim.
Actual repeat offender.
Old 01-07-2013, 07:52 AM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
If the connection failure was at the control horn of the elevators itself, yeah... the trim wouldn't even help you as that bolt is also keeping the two elevator halves together. With the 10's asymmetrical trim system, you'd be out of luck.
BUT, that's not where this disconnect happened (according to an earlier post). The nut was supposedly missing from the WD1010 control column. In this situation, the AP servo (which connects near the F-635 Bellcrank) would have still been connected and useful, as long as the F1089 pushrod didn't jam up somewhere. and when you're on short final at 75' above the runway, there isn't much time for anything other than realizing something is wrong.
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
Old 01-07-2013, 10:38 AM
jrs14855 jrs14855 is offline
Default Weight Shift
On the first Cassutt Racer, Tom Cassutt had the bolt between the pushrod and elevator come loose. He landed the airplane by shifting his weight. No damage to the airplane.
Elastic nut, the nut had been used for holding something during welding and the elastic was burned.
