Old 12-26-2012, 11:23 AM
hydroguy2's Avatar
5*F in this pic during a lunch stop in Bozeman(BZN) during phase 1 testing
I recall 2700fpm climbing out, so on the way home I think it was -5f at 6500' so I tested the straight and level, WOT, 2620rpm....194Kts TAS WooHoo!
I normally don't like to open the hangar door if temp is <10F. Actually I worry mostly about cracking my canopy, going from heated at 50F to 0 or whatever. I broke a headset at -5 in the club 172 picking it off a cold glareshield one day.
Old 12-26-2012, 11:31 AM
gerrychuck gerrychuck is offline
My limits used to be based on how cold I could tolerate it when pre-flighting the plane outside (usually in the wind). Now I can preflight in the shelter of the hangar, and I have very good preheat for the engine, but I have kept my limits at about -20C or about -5F. It's not that it's too uncomfortable either preflighting or flying; it's survivability if I had to put the airplane down off-airport and wait for help. I never really thought about that for years, but started taking it into consideration when my son starting flying Harvard II's (T6's) at the training base here. Their temperature limits are based purely on survivability after an ejection, which started to make sense to me. Plus I'm getting to be a wuss as I get older
Having said that, there is absolutely nothing like flying on a clear, cold, windless day on the Canadian prairies; it can be magic-carpet smooth with takeoff and climb performance to burn. The other thing that people rarely mention is how easy that dense air makes landing; your ground speed for a given TAS is so much lower at these low temps and the dense air gives such a beautiful cushion in ground effect. Everything seems to happen in slow motion and you just settle sweetly onto the runway after flaring.
Jeez; I'm looking out the window at a gorgeous sunny, cold day and this is really making me want to go flying. I really need my medical back....
Gerry Julian
Moose Jaw Saskatchewan
RV6A "Second Wind" C-GERZ (born N242UL)
O-360 A1A, Sensenich FP prop
Those who think any system is foolproof greatly underestimate the ingenuity of fools
Old 12-26-2012, 01:40 PM
PaulR PaulR is offline
Default Steering
So I'm leaving LA (Lower Alabama) tomorrow for a trip to KIOW in Iowa to visit family for a few days. I talked to the FBO and they said there is "patchy" ice on the runway and braking is "fair". (5000' runway) How concerned should I be about steering on that runway/taxiway? I've never had the RV on any snowpack. The old PA-28 was a different story with nose wheel steering, though NO WHERE nearly as much fun!!!!
I opted out of my first choice of airports to stay at due to it being 100% snow and ice packed.
Paul Rose
RV-9A 91300
N417PR
SERFI 2013 Awards
Inspection Complete!!! 7/7/12
First Flight 7/22/12
Old 12-26-2012, 02:22 PM
zilik's Avatar
zilik zilik is offline
VAF Moderator
The "A" models steer just fine using rudder only. Braking is the issue. On snow packed surfaces I have had no problems. On ice you need to be really careful.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
Old 12-26-2012, 04:04 PM
Dogcowdaddy Dogcowdaddy is offline
As a rule of thumb I generally don't fly when the temperature is less than my age. Started flying at 15 and now at 53 I can say that it works out about right :-)
V/R
Jim
Old 12-26-2012, 04:18 PM
n82rb's Avatar
n82rb n82rb is offline
about 65 F. why do you think I live in southwest florida.
every time I move I go farther south. key west is looking real nice.
bob burns
N82RB
RV-4
Old 12-26-2012, 08:20 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
I used to think I wouldn't fly if the temp were much below freezing. But, in the last few days I've logged about five hours cruising around central Minnesota at about 5 degrees F. It has been the most enjoyable flying I've ever done. Smooth air with tons of power and lift. I've had the heater and defrost on the warrior set at about half, and only need to wear a sweatshirt.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 12-27-2012, 05:30 AM
Dennis_I's Avatar
Dennis_I Dennis_I is offline
As long its not colder than -30 Celsius here in the northern part of Sweden
Dennis Isaksson
G?llivare, Sweden
Grew up with an RV-4, SE-XIO
Now: RV-8, Showplanes Fastback. #83218 Under construction, SE-XXO
Engine and avionic installation in progress
Old 12-27-2012, 07:15 AM
6S4 Hugo's Avatar
6S4 Hugo 6S4 Hugo is offline
Originally Posted by sprucemoose View Post
-459.67 F.
0.0 K if that is easier to remember.
I would expect the aircraft and its systems to behave strangely as all atomic motion comes to a standstill.
Old 12-27-2012, 07:20 AM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default cold!
Flying in the cold can be dangerous. I have experienced hyporthermia in my Super Cub,
Several RV8 owners have had cracked canopys because of cole temps.
My limits are,,,, is it nice enough to go for a walk in a light jacket? If yes, flying will be comfortable too.
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
