12-25-2012, 06:55 PM
Work Bench Size
I am currently working on getting my shop area, equipment, and tools put together. After looking and many builder sites, I would like to hear from others on minimum work bench widths. I have constructed one EAA that is 24 x 60 and was planning on building one more and setting them end to end.
I my concerned that the 24" width is too narrow. All feedback is welcomed.
12-25-2012, 07:03 PM
I built mine using only 1 EAA workbench and I put it on wheels to make it easy to stow in my garage. And now it works great over at the hangar!
I did have my normal garage workbench for tooling - dimpler, grinder and tools.
As I finished each piece I hung them up on the wall out of the way.
Good luck!
John Mastro
RV-8
12-25-2012, 07:04 PM
If you have the room I'd go bigger. My bench was 4' X 10'. Large enough for a wing with room for tools, etc around. The large size also came in handy when I had several things going at once.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
12-25-2012, 07:48 PM
Mine is about 40" x 5'. The extra depth was handy when working on larger pieces, like wing skins. If you have room for 2 of the EAA benches & can set them up either way, that should work out fine. Bonus info: if you're using a C-frame & mallet for dimpling, a very rigid & massive surface under the C-frame helps a lot. You can move it to the floor, or build a very massive table top. I lucked into some sections of maple bowling lane (~3" thick) & used that for my work bench top.
edit: being able to work all the way around the bench can come in handy, too.
Charlie
Reason: more info
12-25-2012, 07:54 PM
30" x 16 feet along one wall where there is a vice, drill press, belt sander, and bench grinder mounted. Two folding banquet tables, dimpling table and one for painting small parts. In the same way that you can't have too much money, altitude, fuel, or runway ahead of you, you almost can't have too many work benches (and tools).
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
12-25-2012, 08:07 PM
To a point, wider is better
...mine was 42" x 90", so it would fit into the shop attached to my garage and still allow access to my wall bench. There were just a few times ... Like working on the T/U canopy Fairing ... When I could have used a tad more width. (I.e. 48" rather than 42"). I definitely would have been hampered by a 24" or 30" width.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
12-25-2012, 08:58 PM
One large one and a smaller one
I made one large one at 48"x8', or one sheet of 3/4" ply wood. I also have one made the same size as the EAA workbench. I use the large one almost exclusively.
I have a vice mounted at one end, so I still have plenty of room for almost every thing else I want to work on. I create a T with the EAA workbench for working on the wings.
Scott
RV-7 N818BG (flying)
Bearhawk Patrol (building)
12-25-2012, 09:05 PM
I've got two fixed ones on walls. They are 24" deep and I should have made them 30". They are 7' and 8' long.
The 3' x 7' one on wheels is great, so far plenty adequate. I used to have a 4' wide table and it was too wide for me.
Bear in mind I'm building an RV-3B, so you might need a different size. But the 24" deep tables are definitely insufficient.
Dave
12-25-2012, 09:16 PM
With bench top grinder, sander, band saw, vice etc I've got something like 40' of bench top space and I still often enough find myself wanting more. I'm pretty sure I could fill any amount of available bench space given enough time. :-)
All of my tops are 24" deep. I can't recall ever really wanting deeper though I do dimple wing skins on the floor.
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
12-26-2012, 01:52 AM
Imbedding the dimplier
I have a DRDT-2 dimplier and I was able to imbed it in the table so the dimpling level was flush with the table top. (I think this would be just as useful with a C frame dimplier) If you make it with an insertable panel you can take out the dimplier, put in the panel and you have a nice long uninterrupted work surface.
Jim
