Old 12-10-2012, 02:38 AM
rmcgann rmcgann is offline
Default SL-30 display
Hi folks,
The LED display of the SL-30 is covered by a polarised sheet and clear protective plastic cover. These components have started to peel from the display and will soon separate completely. Does anyone know how to rebond these to the screen, or will I be reduced to some sticky tape or a very expensive return for repair of a trivial problem?
Cheers
RV-10
VH-XRM
Flying in oz.
Old 12-10-2012, 04:08 AM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
You can order these plastic displays from Garmin, about $30 US, I believe. Just pull the old one off and stick on the new one. They come with the sticky back--just peel off the backing and stick on. Better for you guys than sending the unit back to the States, I guess! I'm on my second one on my SL30 in 10 years flying.
By the way, I didn't have any success trying to re-bond the old one, pretty much a waste of time. I think the heat gets to them more than anything else and they get deformed as well, so you really need to get a new one.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Last edited by Pat Hatch : 12-10-2012 at 04:16 AM. Reason: Added second paragraph.
Old 12-10-2012, 04:10 PM
Thanks Pat - I'll give it a try.
Cheers
Ron
Old 12-19-2012, 03:49 PM
Default SL-30 Display
Hi Pat,
I have attempted to contact Garmin support for a replacement display but I have received a nil response. Our local Garmin support centre here in Melbourne Australia knows nothing of a replacement display kit.
Any chance you or any other listers can provide a Garmin part number for the replacement display? I am not a fan of the stick it back on yourself approach.
cheers
Ron
VH-XRM
RV-10, flying in Oz
Old 12-19-2012, 04:37 PM
Pat Hatch's Avatar
Ron, I got mine from the dealer that I purchased my panel from, Aerotronics. I seem to recall that you have to order it through a dealer, as Garmin will not sell it direct. I don't have a part number but I would think your dealer there should be able to find it for you. Good luck.
Pat Hatch
RV-7 (Sold)
Track Me
Old 12-19-2012, 05:37 PM
GrayHawk's Avatar
GrayHawk GrayHawk is offline
Are you talking about the large faceplate mounted clear plastic or the little sheets bonded to the 4 character LED dot matrix displays?
GH
GrayHawk
My rebuild log: http://www.cherryfamily.net/bill/n63tx/rebuild/
Texas Hill Country Hangar For Sale: http://www.myspicewoodhangar.com/default.htm
Old 12-19-2012, 05:53 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Originally Posted by rmcgann View Post
Hi Pat,
cheers
Ron
VH-XRM
RV-10, flying in Oz
Hello Ron,
Please ask your Garmin dealer to refer to section 4.13 Display Protective Lens Replacement, of the SL30 Maintenance Manual, 190-00853-00.
The part number of the replacement lens is 308-3201-42.
Shoot us an email at the address below if you want any more help chasing this down.
Pat is correct that there is a peel-off backing to this part.
For whoever performs the repair, this repair step sounds important:
- Clean the adhesive surfaces on the bezel using a clean wipe and isopropyl alcohol.
Steve
Garmin G3X Support
g3xpert@garmin.com
Last edited by g3xpert : 02-11-2013 at 11:07 AM. Reason: Updated with correct part number for lens.
Old 12-19-2012, 06:26 PM
For GrayHawk - my display has a large clear plastic exterior with a thinner darker polarising/filter sheet behind. Both have delaminated/separated from the LED screen.
For Steve - thanks for this data - I have passed it on to our local Garmin service centre.
Gotta love this forum.
cheers
Ron
Old 05-17-2015, 06:00 PM
hugo hugo is offline
Default SL30
Thanks again
For the tip,tomorrow will be a call to Garmin,see what happen
Thank guys
Old 05-18-2015, 12:37 AM
Doug's Avatar
Doug Doug is offline
Drop a note to Stein Air or Garmin AT (+01 800525-6726) and have them forward you a copy of a document to assist in identifying the correct part for your radio. Two versions of both the SL40 and SL30 Lens are available. Cost is approx $65.
In preparation for the replacement make sure you have the tiny allan key necessary to remove the knobs from the radio.
Probably a breech of copyright but here is a link to the document.
Thanks again to Stein Air for their excellent support.
Doug Gray
RV-6 completed, flying since July 2010
