Old 12-19-2012, 07:10 AM
plbarrett2004's Avatar
plbarrett2004 plbarrett2004 is offline
Default Forward Spar Assembly Drilled off center
Hello all. This is my first post to VAF, as I have just recently taken the plunge and bought a relatively new, but secondhand, RV-8 empennage kit! It's taken me about 6 months of research, but I'm super excited to be starting the build.
Last night I drilled out two holes that attach the forward spar assembly. Specifically the HS-405 to HS-810. Now the plans and instructions both say that the hole will NOT be centered on HS-810 and to make sure that the proper edge spacing is observed for HS-405. The edge spacing for 405 is fine, but the hole on HS-810 looks to close to the side for my comfort. Thoughts? Am I being overly paranoid?
Thanks!
Peter L. Barrett
CFI, CFII, MEI, CPL-Helo
RV-8 - Firewall Forward in Progress
papalimabravo.com
SEMPER FIDELIS
Dues exempt
Old 12-19-2012, 08:02 AM
N546RV's Avatar
N546RV N546RV is offline
My Mk I eyeball tells me you have about 2D edge distance from the center of that hole, which works out to 0.25". Using this reference (scroll down to Table VIII), your minimum edge distance for that hole should be 0.219".
So assuming my eyeball is correct, you're fine, but you should get the official measurement to be sure.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
Old 12-19-2012, 08:14 AM
Snowflake's Avatar
I may be wrong, but it looks like that top angle is upside down... Shouldn't the flange be towards the outer edge of the spar, not towards the center?
Rob Prior
Old 12-19-2012, 08:16 AM
Philip,
Thanks!
This was literally the first thing I've done on the kit since I bought it secondhand, and was a little worried. I'm still missing some really key tools... like a good ruler... the one I have doesn't have small enough increments. Time for a trip to harbor freight.
-Peter
Peter L. Barrett
papalimabravo.com
SEMPER FIDELIS
Dues exempt
Old 12-19-2012, 08:19 AM
Rob,
Previous builder completed the work on both the reinforcement angles. I thought it was correct, but I will certainly be checking the plans as soon as I get home. I sure hope its not upside down!
Peter
Peter L. Barrett
papalimabravo.com
SEMPER FIDELIS
Dues exempt
jthocker's Avatar
jthocker jthocker is offline
Rob is right the angle is upside down.
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 12-19-2012, 08:52 AM
Rob, Jon thanks for the catch. Looks like I have my first part order for Van's.
Peter L. Barrett
papalimabravo.com
SEMPER FIDELIS
Dues exempt
Old 12-19-2012, 09:10 AM
N546RV's Avatar
Yikes, good call, I didn't even notice!
Originally Posted by plbarrett2004 View Post
Philip,
Thanks!
-Peter
Go ahead and snag yourself a set of digital calipers in addition to a good ruler; definitely good for making precise measurements.
And don't worry about the part order - it happens. I had to replace both of my HS spar reinforcements after I horribly botched the tapering job. At least in your case someone else made the mistake!
Philip
Old 12-19-2012, 09:43 AM
Thanks Philip. I will endure to fight another day! Thank heavens for this website and such a great community. I'd never have the confidence to take this project on without it...
Peter L. Barrett
papalimabravo.com
SEMPER FIDELIS
Dues exempt
Old 12-19-2012, 11:08 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF!
Peter, To the good ship VAF.
Good to have you aboard
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
