Originally Posted by newamiga
I would think one option for the D180 -12's would be the Garmin GTX 330 ES transponder to replace the 327? It wouldn't be as inexpensive as the Dynon solution for Skyview I suspect.
Carl
The Trig TT31 (same panel size as the 327) or the TT22 (2 1/4 panel mount) are are fully ADS-B compliant and a bit more economical than the 330ES.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
