12-12-2012, 10:12 PM
Pro Seal Screw Up
I have been so careful before I cut, drill, deburr, dimple, or countersink.
I re-read the plans and the manual 2 or 3 times before I proceed, making sure everything makes sense to me before I proceed. Never thought that deeply about priming everything at the same time when I had great weather. You see it coming don't you. There I was fat dumb and happy priming outside in 70 degree weather in December. Looks great too! Only problem I primed both my trailing edge on the rudder and the wedge. Pro Seal will never stick to primer will it? I guess I'll be stripping all of that off tomorrow unless you guys have a brilliant plan B! At least no metal was permanently injured!!
Bill Stockburger
RV-7A Slider
IO-360 M1B Thunderbolt ordered, Hartzell 74" Composite ordered.
Empennage Finished (except fiberglass), Wings Finished (except FG), Fuselage in progress. Restarted project 6/15/2020
N776DD (Reserved)
2020 Dues Paid
The test of a first-rate intelligence is the ability to hold two opposed ideas in the mind at the same time, and still retain the ability to function. - F. Scott Fitzgerald
12-12-2012, 10:22 PM
No worries. The pro-seal is only there to tack the pieces together during riveting. The rivets hold everything together, not the sealant.
John Siebold
12-12-2012, 10:51 PM
Out of pure dumb omission I neglected to pro-seal my trailing edge. Turned out fine.
12-12-2012, 11:28 PM
Are you kidding?
"Pro-seal will never stick to primer, will it?"
Pro seal will stick to anything.
Steve McGirr
RV7 N1991M
First Flight: May 18, 2013
12-13-2012, 12:24 AM
As Steve said, Pro Seal will stick to anything that isnt currently in liquid state. Ive used Pro-Seal (well at work its called 8802) on rubber, metal and everything in between.
12-13-2012, 03:25 PM
Oh yeah it will stick to anything and gets on everything! I ordered some a while back and when I hung up the phone I had some on my ear
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
12-13-2012, 03:58 PM
Bird
Dang that's funny
12-13-2012, 06:10 PM
plus one
Originally Posted by diamond
Dang that's funny
Yeah, I thought Bird's joke was funnier than my pro seal joke. So I will use his from now on.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
12-13-2012, 10:36 PM
Pro Seal Screw Up
Thanks for the quick answers guys! Just to be straight, don't try removing primer and just build on, because the pro seal will work just fine on my primed trailing edge and wedge. Right?!
Bill Stockburger
RV-7A Slider
N776DD (Reserved)
2020 Dues Paid
12-14-2012, 12:47 AM
You got it.
I did the same on my 7 and it`s fine. Primed all parts then used proseal to hold it straight before riveting.
Just remember not to prime when you get to the fuel tanks!
