  #11
Old 12-12-2012, 07:48 AM
YellerDaisy's Avatar
YellerDaisy YellerDaisy is offline
Originally Posted by Brantel View Post
Foam on the skins between the bulkheads and a board laying on top of that is how I did and do it on my 7. It works for my fat butt. May have to be more careful with the 12 however since its construction is lighter.
I just spent some time in the tail of my -3 recently and this is what I did also. Lots of smaller peices of styrofoam "board" with some thin wood on top (the real thin backing board type stuff) with a bunch of blankets/padding on top of that.
BTW: The time I spent in the tail was to modify it to carry my ski's (documented at Ski Truck Epilogue) - can't wait for the ski season to start!!!
JD
RV-4 - 160HP O-320 - Sensenich GA
RV-3B - O-320 - "Daisy" (sold)
http://jdfinley.com
Old 12-12-2012, 10:10 AM
sf3543 sf3543 is offline
If you follow VANs directions while you build there should be no need to crawl into the tail cone. I didn't need to for my build and everything worked out.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
RV8
Old 12-12-2012, 10:14 AM
This may be true during the build process (I'm not a -12 builder). If talking about after the build, there is a need for inspection and maintenance back there. Probably could be done with inspection panels though. Inspection panels would kind of take the adventure out of the event though!!
JD
http://jdfinley.com
Old 12-12-2012, 10:57 AM
txaviator's Avatar
txaviator txaviator is offline
I have followed the plans to the letter...never strayed out of order at all. But I'm thinking there is a need to get back into there, after the main plane is built, to install some of the Skyview avionics components? As some have pointed out, you don't have to go in there very far, but I will need to enter the tailcone a few feet for component installation. This is per the plans, to install the ADAHRS box, I think (**edit: yep, just as Dave points out in his post and photos)...I'm not that far yet, but there is an ADAHRS bracket at the very top of the tailcone- a few feet in, that gets something hooked up. I'm hoping that I can kind of reach that from the cockpit, as did Dave and others.
Thanks for the replies and ideas, everyone!
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
Old 12-12-2012, 11:44 AM
RVTrumpet's Avatar
RVTrumpet RVTrumpet is offline
What we did: It turned out not to be too big of a problem crawling back there. We layed down strips of foam on the closest tailcone bulkhead and then place a board on top of that. Since we had already run our control cables we were careful to place them between the strips of foam and not squish them into the bulkhead. There is also a plastic control cable guide that is attached to the bulkhead, and it sticks up above it about a half inch. We were careful not to lay the board on this, and were also careful not to shift the board when we were laying on it.
What we should have done: If you can, leave the tailcone off as long as possible. It will be alot easier to access the tailcone and the fuselage section if they are seperate.
Support your tailcone before you climb in it on a sawhorse or other retaining device!!
RV addict for life.
NOTE: The information, ideas, and opinions presented in this post are my own and not those of my employer. Build, test, and fly at your own risk.
Old 12-12-2012, 12:03 PM
GAHco's Avatar
GAHco GAHco is offline
Talking Foam Blocks
I made Styrofoam to put in the tailcone. I used 1" foam,stacked to 3 inches.
I used white glue and let the panels dry under weigh of books or wood for a couple or more days.
It is easier if you find 3" foam but this is what I had.
Cut to shape once the foam is ready on a band saw, put the foam in and do what you need to. DO NOT fly with this foam in the aircraft.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 12-12-2012, 12:35 PM
Dgamble's Avatar
Dgamble Dgamble is offline
Originally Posted by txaviator View Post
This is per the plans, to install the ADHARS box, I think
I failed to mention that I followed the advice of a rather sharp fellow builder who suggested that it would be easier to mount the ADAHRS box to the mounts and then rivet the whole assembly in at once. He was absolutely correct!
Dave Gamble
Grove City, OH
RV-6 N466PG Purchased already flying - SOLD!
The Book: The PapaGolf Chronicles
Built RV-12
http://www.schmetterlingaviation.com
The Book: Being written.
The above web blogs and any links provided thereto are not instructional or advisory in nature. They merely seek to share my experiences in building and flying Van's RV airplanes.
Old 12-12-2012, 01:02 PM
bhassel's Avatar
bhassel bhassel is offline
Gosh I hope I remeber this thread several months down the road....
Bob
Bob Hassel
NM
Subscription Paid for 2020
Home is where the hanger is...
Old 12-12-2012, 01:25 PM
I took a different approach, I added 4" inspection ports one the side near the tail (for counter weight access) and along the bottom centerline for wear plate access and autopilot servo inspection.
Old 12-12-2012, 02:30 PM
txaviator's Avatar
Sounds like GREAT advice, but I have already riveted the mount to the top of the fuse. I'm not where I can view the plans, but if IIRC, that's just held on with a 4-6 rivets. Sounds like I'll remove the bracket if able, mount up the ADAHRS equipment, then re-rivet!
I should have left the tailcone off, but again, I just followed the plans. If I build another one I'll leave the tailcone off for sure until some of these steps are done!
Thanks everyone.
Gary Robertson
Arlington, TX
