Old 12-05-2012, 07:25 PM
Golf Echo's Avatar
Golf Echo Golf Echo is offline
Default Riveting separation
Greetings,
Hopefully I don't win a prize for dumbest first post ever, but here goes...
I've received and inventoried my empennage kit for what will someday become an RV-7. I've pondered my choices for engines and avionics, but today, my question is a little more rudimentary...
In riveting the reinforcement plates and ribs to the spar (of the practice kit) I'm getting some deformation and separation of the rib flange (see photo). I'm using the Cleaveland pneumatic squeezer to set the rivets. Is this simply an issue of inadequate clamping? I tried putting a cleco clamp near to the rivet being set, but it didn't seem to help. I'm going to drill them out and re-rivet for practice, but I figured somebody might have seen this before. Any thoughts?
Thanks in advance for the help. This site has already been an enormous resource for me.
Graham
RV-7
Empennage [in progress]
Wings [inventoried]
The plan(?): Tip-up | AeroSport IO-375 | WW 200RV | Vertical Power VP-X | Garmin G3X
VAF dues paid - Dec. 2013
Old 12-05-2012, 07:53 PM
aerhed aerhed is offline
Tweaking that flange to fit as flat as possible will help. Even so, sometimes you get spreading like that. Lots of ways to deal with it, but try a tiny pair of needle nose vise grips (taped jaws) on each side of the hole. Tricks like that start coming natural after awhile.
Actual repeat offender.
Old 12-05-2012, 07:55 PM
You oversqueezed a bit too.
Old 12-05-2012, 08:06 PM
frazitl's Avatar
frazitl frazitl is offline
Default My suggestion is
that the parts should be "nested" together better before riveting. Try squeezing the whole assembly with your dimple dies before riveting. I did this a lot resulting in much better fit and riveting results...
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
Old 12-05-2012, 08:09 PM
RV7AJeremy's Avatar
RV7AJeremy RV7AJeremy is offline
Default Rubber grommet
Put a rubber grommet over the tail before you squeeze. As the squeezer starts to "squeeze" the rubber will compress all the parts together and then the shop head will form. Works great. You can get a bunch of them at HF for cheep. Hopefully I explained that correctly.
Jeremy
ATP, CFI, CFII
RV-7 N424JD KCHD
EAA Tech Counselor
2017 Bronze Lindy
Old 12-05-2012, 08:58 PM
Joe Parish Joe Parish is offline
Putting the rivet in the other direction may help in some instances. Although not always possible. Love the rubber grommet idea.
Joe
RV-9A N525XC
Superior IO-320
Dynon HDX
Flying as of 5-4-18
Old 12-05-2012, 09:35 PM
Andrew M's Avatar
Andrew M Andrew M is offline
Default Puckered.
That happens when the set rivet swells the hole and puckers the flange of a thin piece. Set less or reverse the rivit direction. Leave that one alone, you can only make an acceptable joint worse at this piont. the metal has been streched and won't pound compleatly flat.
Andrew Miller
A&P, IA
-9 empennage
Wings arrived 12 JAN 13
https://plus.google.com/photos/11360...J-TuJPsmOONzQE
Old 12-06-2012, 01:02 AM
Golf Echo's Avatar
Seems like over-setting a bit might be the culprit.
The strange thing is that the shop heads of both those rivets fit inside the rivet gauge. Because of that, I didn't think I was over-setting.
Graham
RV-7
Wings [inventoried]
Old 12-06-2012, 01:04 AM
Golf Echo's Avatar
In the Van's documentation, they suggest putting the factory head on the side of the thinnest piece. Makes sense to me. But, in looking at some other's photos, the factory head was on the leading side of the spar, so I did it that way. Not really sure why I didn't keep the factory head with the thin material...
Graham
RV-7
Wings [inventoried]
Old 12-06-2012, 06:47 AM
Jamie's Avatar
Jamie Jamie is offline
This is precisely what side-grip clamps (used with cleco pliers) are used for. It will solve this problem 99% of the time.
