Old 12-04-2012, 09:47 AM
PerfTech's Avatar
PerfTech PerfTech is offline
Talking Anti-Splat Quest for Products
...We are always looking for new products that we can bring to the RV community to enhance the "RV Grin" or experience. In this quest we found something that is needed and many would want if available for their aircraft. We will need to do a few refinements and make mounting kits for the various models, but this looks like a real winner. So you may wish to get your order in early and avoid the inevitable big rush. Let us know what you think. Allan...
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 12-04-2012, 10:02 AM
Default Wing bolt drift pins
Alan you make great mods and your marketing is outstanding. I haven't bought any of your products yet but I will someday.
A lot of people are still building and this maybe a great idea to manufacture these pins. Years ago Tony Lanaken from Belgium was selling his I saved the picture. Many builders are struggling making their own pins from hardware store bolts some of them are using close tolerance and ruining them. Why don't you use use your superb machinery and laser cut extra alodine some of these?
I am positive there will be strong demand for them especially after you make your famous videos
Old 12-04-2012, 10:33 AM
tmbg's Avatar
tmbg tmbg is offline
wing bolt drift pins?
Ian
Old 12-04-2012, 11:18 AM
PerfTech's Avatar
......Thank you for the kind words I assure you they are appreciated. I will have a look at making these sets. Do all of the models use the same size?...
Allan Nimmo
AntiSplatAero.com
RV-9A / Edge-540
(909) 824-1020
Old 12-04-2012, 11:21 AM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
I think so (not sure)... and I'd buy a set as long as they are small enough to go in and out easily but not be too lose.
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 12-04-2012, 11:28 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Nope - I had to make a different set of pins for the RV-3 - could only use some of the pins I made for my -8.... (there is some overlap).
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-04-2012, 11:36 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
If you decide to make the wing pins, machine the head down next to the shank for about an eight inch wide, make the new OD about half of the current head diameter.
This will leave a two step head size, and will allow a pry tool to fit in between the head and the spar.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-04-2012, 11:41 AM
rleffler's Avatar
rleffler rleffler is offline
The RV-10 has two different sizes. I don't know if either size is shared with other models.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 12-04-2012, 11:44 AM
N427EF N427EF is offline
Default Fuel Pump
Ethanol compatible engine driven fuel pump.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 12-04-2012, 11:58 AM
tmbg's Avatar
Isn't tempest's fuel pump ethanol compatible? I believe I talked to them about that last year at oshkosh and they said it was.
Ian
