Old 11-29-2012, 10:32 AM
JBPILOT JBPILOT is offline
Default Thanks Tony - -
It will turn if you have enough speed. I had to slow down to about 60 kts to keep it from turning, Hard to imagine such a case, but if decending at 70 or up, it would start the engine. The thing to keep in mind. If you try what I did, make sure you do slow down enough to stop the engine from turning over. With the mags off, it would build up gas in the engine.
John Bender
478.3 hrs
Old 11-29-2012, 02:23 PM
tim walter tim walter is offline
Default Glide Ratio
What is the glide ratio for a -12 ?
Tim Walter
KDVO
http://rv-12-tim-walter.blogspot.com
kit# 120528
