  #11
Old 01-20-2012, 11:16 PM
Sig600 Sig600 is offline
Originally Posted by Jamie View Post
This is when an iPad or other tablet is priceless. Every manual for every piece of equipment is on mine.
+1
Download the pdf and youre set, upgrade as required.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 11-17-2012, 08:52 PM
socal socal is offline
Default G3X manual
I just received my G3X from Aerotronics for my RV8A its very nice, same prob, no hard copy so I downloaded to thumb drive took it to Kinko's and printed copy for $30, That was the install manual now for the pilot's manual.
Having a prob with it: Lights up nice oil temp & MP indicate normal (Engine Not Running) but ALL 8 EGT's & CHT's are red X.
Updated software, lowered baseline temps to zero, changed Config Module, changed thermocouple in 732 conn. Looks like changing AHARS box next what a bummer !!!
Aerotronics has been great helping to get it fixed, and eventually I'm sure we will but I have lost weeks troubleshooting.
I expected better from brand new garmin.
If anyone else has ideas please advise. Thx
Old 11-17-2012, 09:11 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Default Goodreader
Is an excellent APP for storing and reading PDF files such as this.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 11-17-2012, 09:41 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Hello socal,
As indicated in the installation manual, "All thermocouple temperature readouts will be red-x?d if the GSU configuration module is not present."
It sounds like you and Aerotronics have already recognized that thermocouple measurements only work when both the solid state temperature sensor in the GSU73 config module and the reference thermocouple in the GSU73 backshell are wired and functioning properly.
Perhaps the config module and reference thermocouple wiring has already been carefully checked, but that is the best guess as to what would need attention if everything is working fine but the EGT/CHT probes.
Let us know if you have additional questions.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 11-27-2012, 08:25 AM
HSANTIBANEZ HSANTIBANEZ is offline
Default How Can?
1.- see the % of power betwin MP and RPM
2.- see the data .csv in excell one number in each cell, not all in one cell
3.- when i shut off Auto pilot gx pilot AP doesnt dissapear in screen
4.- I have VPX pro and see the pitch trim display inverted, any solution?
Hern?n Santib??ez
Valpara?so, Chile
RV-7 TMX-IO-360 G3X and VPX Flying over Chile
2018 Dues Paid
Old 11-27-2012, 08:32 AM
g3xpert's Avatar
1. See the "Engine Power" topic in section 12.3.2 of the G3X Installation Manual to learn how to configure the percent power display for a Lycoming or Continental engine.
2. Data log files are stored in .csv format, which stands for "comma-separated value". To open these files in Excel, you need to select "Text Files (*.txt, *.csv)".
3. I'm not sure I understand your meaning on this item, can you elaborate?
4. Pitch trim is displayed in the normal fashion ("up" at the bottom, "down" at the top) using the data from the VP-X unit. Perhaps your senor wiring is backwards?
- Matt
Garmin G3X Support
g3xpert@garmin.com
Old 11-27-2012, 09:28 AM
I mean that there some messages that dont dissapear for example i turn on the system with IBBS to start the engine, then with the engine running y conect the master avionics and shut of IBBS, but the backup battery message dont disapear. in the same case when i shut off the GX pilot the AP continue in the screen
Thanks, these are little items, the system is great and easy tu use
Hern?n Santib??ez
Valpara?so, Chile
2018 Dues Paid
Old 11-27-2012, 09:38 AM
g3xpert's Avatar
Thanks, I think I understand what you are saying now.
If you are removing power to the GX Pilot autopilot unit while it is engaged, the G3X system will interpret this as a fault and will provide an audio alert and display a flashing red "AP" indication that will persist until it is acknowledged. You can acknowledge the "AP" warning by pressing the ENT key, as is mentioned in section 9.1 of the G3X Pilot's Guide. As a side note, it is generally a better idea to disconnect the autopilot using either the "AP" button on the GX Pilot front panel, or the CWS/AP Disconnect button on the control stick.
Regarding your backup battery CAS message, I assume you have the TCW IBBS unit connected to a discrete input on your GSU 73 ADAHRS/EIS unit. The G3X system will simply display the CAS message you have configured whenever the discrete input from the TCW unit is in the state you configured. The TCW IBBS unit we have here behaves identically to what you describe, so it sounds like it is working as designed. Think of this CAS message like a light bulb, it only knows how to be on or off depending on the voltage it sees on its input pin.
- Matt
Garmin G3X Support
g3xpert@garmin.com
Old 11-27-2012, 04:59 PM
Excellent thank you!
Hern?n Santib??ez
Valpara?so, Chile
2018 Dues Paid
Old 11-27-2012, 09:45 PM
Strasnuts Strasnuts is offline
Default Manual
I'm glad I have the G3X. I have had so many software upgrades and configuration updates that make it better every few months a manual would definitely be obsolete. Now if I could have a flight director and VNAV altitudes on a STAR.
A&P RV-10 Flying 1000+ hours
SuperSTOL Flying 170 hours
