Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Interiors
Old 11-26-2012, 01:18 PM
RV7AJeremy's Avatar
RV7AJeremy RV7AJeremy is offline
Default Prime Jetflex?
Hello all, I am looking into different paint options for my interior and I was reading the product data sheet for jetflex and it says "Prime with JetFlex? Primer CM0480930 if required." My question for the group is: Has anyone used the jetflex without priming, and how did it turn out? Not sure how "required" it will be to prime clean, scuffed, new aluminum. Thoughts?
Thanks in advance.
Jeremy
ATP, CFI, CFII
RV-7 N424JD KCHD
EAA Tech Counselor
2017 Bronze Lindy
Old 11-26-2012, 01:23 PM
rleffler's Avatar
rleffler rleffler is online now
I don't know the answer to your question. My fuselage just came out of the paint shop and my painter was anal about ensuring that a good primer coat was on everything before applying either JetGlo or AcryGlo.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 11-26-2012, 04:25 PM
RV7AJeremy's Avatar
Default Prime it is
I stopped by a local body shop and talked to the pros about it. They were adamant about priming, so priming I will do.
Jeremy
ATP, CFI, CFII
RV-7 N424JD KCHD
EAA Tech Counselor
2017 Bronze Lindy
Old 11-26-2012, 04:28 PM
Jim P's Avatar
Jim P Jim P is offline
Default Primed, but with epoxy primer
I did use JetFlex for the interior, but it had already been primed with DPLF epoxy primer. I scuffed that up an applied the JF over it and after 5 years, no problems with adhesion at all.
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 11-26-2012, 05:36 PM
bruceh's Avatar
bruceh bruceh is offline
I used JetFlex interior paint over the Akzo-Nobel epoxy primer. Has held up very well so far (still building). There is some window of time where you can put a top coat over the primer that I can't remember...
Bruce Hill
2020 VAF donator
Old 11-26-2012, 08:41 PM
BSwayze's Avatar
BSwayze BSwayze is offline
I used JetFlex on my interior, too. Much of it was primed with a 2-part epoxy primer, but a lot of was primed with SEM rattle-can primer. But it was all primed. It has held up well in both cases. It's an excellent product.
Bruce Swayze
RV-7A Standard Build
http://www.BrucesRV7A.com
Old 11-26-2012, 09:17 PM
txaviator's Avatar
txaviator txaviator is offline
Where have you guys been buying your JetFlex / SW paints? Just starting to research it, but the first places that their website referred me to, stated that they only sell wholesale. I need to be priming my interior within the next week or so.
I'm in the DFW area, if anyone can direct me to a local source. Thanks.
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
Old 11-26-2012, 11:25 PM
rleffler's Avatar
If you go to the SW aviation paint web site, they have a list of all their distributors online. The one in Chillicothe, OH had no problem selling to me direct.
If the one that stated that they are wholesale only is local, I'm surprised that they wouldn't suggest one of their customers to purchase from
Bob Leffler
Old 11-27-2012, 12:51 AM
xblueh2o xblueh2o is offline
Don't know about close to you but Alliance Coatings in So Cal is where I get everything I need. Very knowledgeable folks.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 11-27-2012, 01:08 AM
Ressum Ressum is offline
Call Aero Performance. Located by Mecham Airport I believe the number is 1800TEXAIR.
