Go Back   VAF Forums > Model Specific > RV-3
  #21
Old 06-23-2011, 09:38 PM
Bill Wightman's Avatar
Bill Wightman Bill Wightman is offline
Nice work Paul. I like your "set it and forget it" ideology. That's pretty much the way Boeing did the 777 (except we've got like 16 levels of redundancy). And like the Triple, your critical buss gets fed automatically if either of the feeds fail. Boeing calls those things "transfer busses".
Well done!
?The important thing in aeroplanes is that they shall be speedy.?
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
Old 06-24-2011, 12:10 AM
vlittle's Avatar
vlittle vlittle is offline
Steve - I am with Walt (obviously) on using a switch alone when you can instead of a switch and a relay. I've just seen enough relay failures, and fewer switch failures. You need to make sure that your switch is adequate for the job, and if it is - get rid of one failure point!
Paul
I've had several switch failures in my RV. Switches that carry incandescent lighting loads (landing, taxi) or strobe power supplies are highly stressed, and I will be using relays for these types of loads in my Rocket. When/if the relays fail, they are easy to replace... even in flight.
This may be the fault of the switches (search the aeroelectric list for my failure analysis).
The only conclusion... design for maintenance. If you have to fix something (and you will), make it accessible. Everyting breaks eventually. I don't even know if you can crawl into an RV-3!
V
V e r n. ====
RV-9A complete
Harmon Rocket complete
Part of EAA award-winning OnSpeed team
The VV in huVVer.tech
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 06-24-2011, 03:55 AM
shuttle's Avatar
shuttle shuttle is offline
Originally Posted by Walt View Post
I just think switches are more reliable than relays, so if I can use a switch I will.
Paul
Paul/Walt, Thanks. I'll review that decision of mine once more. The switch is already man enough to take the load. I'm using Eaton toggle switches.
I also just noticed the 60 amp ANL, if you're using a 60A alternator I would suggest stepping that up to an 80 ANL to prevent nuisance blowing of the ANL.
Walt,
I'm not so sure that 60A ANLs with a 60A alternator are such an issue. My understanding is that the ANL current limiters are very slow blow that can take a good deal more than the rated current indefinitely. According to the Bussman ANL spec sheet even a 50A rated ANL will take 100 seconds to blow when exposed to about 110A. See the chart below. If anyone understands the logic behind the rating scale for ANLs I'd be keen to learn.
I'd also be interested in hearing from folks that have had nuisance trips on 60A ANL/60A Alternator combos and solved it by uprating to an 80A ANL.
The above is cut from http://www.cooperindustries.com/cont...S_2024_ANL.pdf
Thanks again,
Steve
Steve Hutt
West Sussex, UK
RV-7 G-HUTY (not flying yet)
( Tip-UP / TMX-IO-360-M1B / Hartzell 7497-2 / 1x LSE PLASMA III / Dual AF4500's / AF-Pilot AP / 695 )
Old 06-24-2011, 07:01 AM
Walt's Avatar
Walt Walt is offline
Originally Posted by shuttle View Post
Paul/Walt, Thanks. I'll review that decision of mine once more. The switch is already man enough to take the load. I'm using Eaton toggle switched.
Walt,
I'm not so sure that 60A ANLs with a 60A alternator are such an issue. My understanding is that the ANL current limiters are very slow blow that can take a good deal more than the rated current idefinitely. According to the Bussman ANL spec sheet even a 50A rated ANL will take 100 seconds to blow when exposed to about 110A. See the chart below. If anyone understands the logic behind the rating scale for ANLs I'd be keen to learn.
Thanks again,
Steve
Steve,
After a review of the ANL chart above I will agree with you, stay with the 60A. My hanger mate blew an ANL after installing a plane power alternator, but I'm not sure what size it was but I'll find out (I was thinking it was a 60 but I'll double check).
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 11-20-2012, 09:17 AM
use a switch alone when you can instead of a switch and a relay. I've just seen enough relay failures, and fewer switch failures.
Paul, I am trying to address my new electrical design and agree it would bve nice (and easier) to use a switch rather than a switch+relay.
I want to have my 60A feed from the alternator/battery spit to essential and non-essential buses.
What source and what switch have you found for 20A or 40A circuits ?
Also, you use "twin-pack diodes" - could you share the MFG and part # ? I have not been able to figure out how to size these diodes.
Old 11-20-2012, 10:39 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I'm traveling right now Glen, so don't have the part numbers for the diodes - but I know that Christer at Steinair does - give him a call!
As for large-capacity switches, well - if you're trying to switch anything 20 Amps or larger a relay is probably more appropriate. I prefer not to use relays any more than I have to, as I said, but for large loads, you are kind of stuck. I really prefer not to have relays in my critical path to get power to essential loads - the fewer active components between your source and critical loads, the better.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-20-2012, 11:19 AM
Thanks Paul.
I agree to the desire for switches over relays. What was confusing me in the RV-3B diagrams and photos was I did not see any relays for the buses and I did not see any large breakers. What I did see was one or two primary switches and lots and lots of individual component breakers.
I must have missed the point of protection for your essential bus. That is what has been confusing me on most of the threads.
Once I have the fundamentals down, I will write it all up with diagrams and share it back on VAF.
Old 11-20-2012, 12:57 PM
Ironflight's Avatar
True - that was a system's level architecture drawing - not a wiring diagram that showed all components.
Paul F. Dye
Old 11-20-2012, 01:47 PM
So, for the actual implementation, did you find a hi current switch or did you use a relay ?
I've found a suitable relay but not a suitable switch at the bus current loads.
Old 11-20-2012, 01:49 PM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
Given the expertise here, here is our proposed more "minimal" RV-3 Elec layout:
No Master (Electrical) Relay, may include a mechanical battery isolation sw. Start Master sw is to remove a single point failure leading to activation of the Starter. Comments welcome
Andy
