Old 11-19-2012, 04:07 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Default best L/D ?
Has anyone really worked out the best L/D for an RV10? assume 2700lbs.
Just never seen it anywhere on the forum.........
David Brown
Old 11-19-2012, 06:24 AM
azcloudflyer azcloudflyer is offline
See flight testing section of my web page for details.
Mike Andresen
Apache Jct, AZ
www.azcloudflyer.com
Old 11-19-2012, 07:33 AM
flion's Avatar
flion flion is offline
It's a little hard to tell from that plot - what airspeed is that at? By the way, nice section on your testing, Mike.
EAA Technical Counselor #5357
Old 11-19-2012, 07:47 AM
sailvi767 sailvi767 is offline
Very nice flat curve at the top. It looks like for practical purposes anything from 82 to 102 knots would put you very close to optimum. Does anyone have a similar chart for the RV6?
George
Old 11-19-2012, 08:48 AM
Strasnuts Strasnuts is offline
Default Thanks for sharing
Great info and nice work putting the charts together on your website.
A&P RV-10 Flying 1000+ hours
SuperSTOL Flying 170 hours
Old 11-19-2012, 09:06 AM
az_gila's Avatar
az_gila az_gila is offline
Question
Since the -3 degree setting appears to be more efficient over the whole speed range, is there any reason to ever use the zero degree setting?
Is controllability better with the zero setting?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-19-2012, 12:09 PM
One notch (0 degrees) of flaps will get you up off the runway a little sooner. Plane accelerates so well you do have to be careful to retract any flaps before exceeding flap down speed.
In my testing I came up with 87 kias for best glide, gross weight, with a likely error bar of plus or minus 5 knots. e.g., in agreement with the above plot.
Old 11-19-2012, 12:31 PM
az_gila's Avatar
Question
In my testing I came up with 87 kias for best glide, gross weight, with a likely error bar of plus or minus 5 knots. e.g., in agreement with the above plot?
Does zero flaps count as flaps down?
Usually it does not...
Gil Alexander
Old 11-19-2012, 12:58 PM
Auburntsts's Avatar
In the -10 I'd say yes simply because full "up" is the -3 deg reflex position and is the standard "no flap" position. The zero degree position just happens to be a defined position between full up and full down, no different terminology wise than say 15 deg. Confusion may arise from aircraft (eg Cessna's) where zero deg is the full up flap position and reflex is not an option.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 11-19-2012, 01:05 PM
Yes. Vans lists maximum speeds for the 3 standard flaps down positions, including the first one (0 deg).
The reason is structural; with flaps up (-3 deg) the flaps are against the aft spar. In other positions the forces which want to force the flaps up are carried by the flap push rod.
