Old 11-18-2012, 02:27 PM
jdeas's Avatar
jdeas jdeas is offline
Default Best way to lift a tailwheel
Looking for the best way to lift a 7 off the gear so I can do the wheelpants.
Engine is on tail feathers off so it's front heavy.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
Old 11-18-2012, 02:55 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Are the wings on??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-18-2012, 03:08 PM
DRBuilder's Avatar
DRBuilder DRBuilder is offline
Default Lifting a tail dragger
I set some weight on the back deck and strapped an engine hoist to the motor mount. Worked perfectly. I only lifted one side at a time though. Never tried to lift both sides at once......
Dennis Roberts
Wake Forest, NC
EAA 1114, Apex, NC
N713DR Super-7 IO/540 SOLD
http://www.drrv7.com
Old 11-18-2012, 04:10 PM
jdeas's Avatar
Default Wings
Wings are off. I was thinking of using the wing jacks on the firewall corners with a wood block to spread the load.
I did the engine lift on a 7A and it worked great but it falls apart a bit with the tail wheel config
JD
RV-7 N314SY (KWHP)
IO-360-B1B
Old 11-18-2012, 04:19 PM
Best choice is to do this before mounting the engine, but in your situation I'd use broad straps on the big engine mount tubes and as close to the bolts as possible. Put a little weight on the tail deck and you'll be fine.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-18-2012, 04:43 PM
Mike S's Avatar
Senior Curmudgeon
I used jacks under the spar carry through on the 10-------but I do not think your plane has these. Is the structure under the belly strong enough to hold the weight if jacked up there?
Photos here. http://www.vansairforce.com/communit...ad.php?t=68674
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 11-18-2012, 05:17 PM
jdeas's Avatar
Default Good thread
Thanks for the thread. It will be useful this week. The jack point for me (no tail feathers and engine on) seems to be the firewall corners under the steel gussets.
Just kinda afraid to do it there as I have never seen it done like this.
I tried the main spar but the amount of weight I would have to add to the tail to keep the engine up was uncomfortably large.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
Old 11-18-2012, 06:11 PM
dsvajda's Avatar
dsvajda dsvajda is offline
Here's how I did it on my 6. Used the bottle jack and a 4x4 block to lift and then rested it back on the 4x4's on the jack stands. Jack and stands courtesy of Harbor Freight.
Dave
RV-6
Waiting for calmer winds
to resume Phase I flights
Old 11-18-2012, 06:24 PM
jdeas's Avatar
Default Same thought
kinda what I had in mind myself. I built a couple of wing jacks with the same cyl. I was thinking of pulling the exhaust though. I figured if I lifted the tail first that this might be a way to get it done.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
Old 11-18-2012, 06:25 PM
At each condition inspection on my RV-8, we jack from the landing gear mounting point. On a -7, is this forward of the CG? If so it is designed to carry the weight of the entire airplane.
