Old 11-09-2012, 02:39 PM
JOEPILOT JOEPILOT is offline
Default Flare tool?
What is the best flaring tool for the 12 without breaking the bank?
Old 11-09-2012, 03:14 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
One you can borrow from a buddy
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-09-2012, 03:44 PM
Im trying to decide if it is worth just having one of the hose companies build them for me. I have never liked the "flare" fittings using copper tubing. I have seen too many leaks from kinks and bad flares. That scares me when the lines run through the cockpit. I like the stainless steel braided flexible lines - especially the line that connects to the wing tank from the valve.
Maybe I am worried about a problem that isn't there, but sometimes peace of mind is the way to go.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 11-09-2012, 03:45 PM
Default Wow!
Now, that's comedy there!
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
Old 11-09-2012, 04:10 PM
Rich_in_AK Rich_in_AK is offline
If you have a local EAA chapter they might have one you could borrow for a couple days. Flaring aluminum tubing is easy and fun once you pratice on a couple flares first. I have never had any problems with leaks or breaks on any flared connections I have done in my planes.
RV-8 flying, RV-7A flying, CH-750 flying, RV-14 next
Old 11-09-2012, 05:28 PM
I bought my RFT37 from Tom Brink at GAHCO. Its excellent!
Ridgeland, SC
Old 11-09-2012, 06:21 PM
yankee-flyer yankee-flyer is offline
Talking That's exactly what I did
And he showed me how to use it, too!!
Wayne 143WM
Old 11-11-2012, 01:49 PM
keny keny is offline
Default Flare Tool
No question, Try to borrow because if it is good quality and you do it right, it may be the last time you have need. Light Plane Maintenance(I've subscribed for years and highly recommend even though all topics don't relate to experimentals) rated flaring tools in the November,2010 issue(nothing new since then). the Weatherhead was rated as best and I was lucky enough to borrow this tool. It makes beautiful flares easily. The cost is the hard part at $744. Aircraft Spruce sells this and two that appear the same for $300 and $80 that I believe you can return if you aren't happy with the outcome. The most important tool, per the article, is a good tubing cutter. Aircraft Spruce has a very good, Imperial Brand, cutter for $30. Don't go cheap here. The hard part is bending the tubing in the right places so the tube goes through various grommets, etc. Plan on buying extra tubing as you will throw some away. Hope this helps. Ken
Old 11-11-2012, 05:49 PM
thomasyost's Avatar
thomasyost thomasyost is offline
Someone posted a recommendation for this tool last time I saw the topic come up:
http://www.aircraft-tool.com/shop/de...ODUCT_ID=212FB
I was very happy with the results and thought the price was reasonable for the quality of the tool.
Harbor Freight sells almost identical tube bender for a LOT less:
http://www.aircraft-tool.com/shop/de...ODUCT_ID=368FH
http://www.harborfreight.com/tubing-bender-3755.html
I ended up buying a second set of the large tubing since I used the first set for my "education".
Tom
RV-12 #285
Finished fuselage kit.
Keaau, HI
Old 11-11-2012, 06:52 PM
Joe I know somebody who just bought new flaring tool.
I don't think he will be using it anytime soon and he never been to Linden. Two slices of regular pizza and a diet coke will be good price to rent.
