11-09-2012, 08:05 AM
Originally Posted by txaviator
Found the $324 crimper too, deemed it absurd to buy it for a total of 10 terminals to crimp, although another way to look at it is $32.40 per terminal, peanuts compared to the cost of the Rotax!
On the other hand and in the same line of thinking, at 100HP the cost per HP of a Rotax engine ain't that bad!
Reason: additional comment
11-09-2012, 08:18 AM
Originally Posted by bhassel
Would those same people solder or crimp?
I would guess that a large part of that group might solder. Soldering is more of a problem where vibration is present. I doubt there is much inside a nine pin D-sub connector with the wires being clamped down. I used some of these on my 9A years ago and have had no problems.
Bob
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
11-09-2012, 09:15 AM
Let me see if I can find one a little cheaper in price than the $324 version. If I can, I will gladly buy one- then we can rent it out amongst us -12 builders for say, $30 per plane/builder? Just an idea...
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
11-09-2012, 11:51 AM
RV-12Wiring
Steinair has an open barrel crimper for about $65 that works with those tiny pins.
11-09-2012, 01:42 PM
IT seems to me like some of you are just looking for ways to add time and dollars to your project ! Are you afraid you might actually have to fly it some day?
On all my planes I just soldered the wires together with shrink wrap over it. Quick and inexpensive and never had a problem. If you ever have to disconnect it ( and I never did) just cut and redo it.
RV-8 flying, RV-7A flying, CH-750 flying, RV-14 next
11-09-2012, 02:27 PM
See posts 27 & 28 this thread. http://www.vansairforce.com/communit...t=92407&page=3
Not specific to tiny pins, but thoughts re: soldering.
John Peck, CFII, A&P, EAA Tech Counselor, Flight Advisor.
?Master Pilot? Award, UFO Member.
RV-12 N37JP 120176 Flying since 2012.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
11-10-2012, 05:24 AM
Got it done!
I noticed that my regular crimper was the same width as the two tongues to be crimped so I did both crimpings in one shot. It worked. The trickiest is to strip these tiny ends and position the insulation correctly as only 1/16th of an inch need to be crimped. I'm lucky I still have good eyes at "umpty"!
Reason: Typos
11-10-2012, 07:21 AM
small connector pins
I just bent the tabs close to the pin over with a small set of pliers and soldered. I then bent the outer tabs over the insulated part of the wire. Seems sturdy enough for me.
Joe Arluck
Livermore, CA
RV-12, S/N 120419
Empennage/Tailcone finished
Wings finished
Most of Finishing Kit finished
"It's sitting on the Landing Gear"
Engine mostly installed
Avionics Kit in Hand
Currently fitting wings
Paid 2018
11-10-2012, 10:09 AM
I've just done these using the two smallest jaws on Steinair's SAT-18 ($31) open barrel crimper as per the instructions in Section 5. I was a bit doubtful when I looked at the size of those tiny pins, but they actually worked fine.
rgmwa
RV-12LR 912ULS
120346
11-10-2012, 06:14 PM
I heard at EAA today that new kits from Van's come with these connections completed. Any truth to that?
John Horn (donated for 2020)
Independence, OR
LSRM-A, CFII
Rotax Service, Maintenance, and Heavy Maintenance Trained
Building an RV-12, N7878H reserved
Flying a Flight Design CTSW
