Old 11-04-2012, 05:40 PM
climbingduo climbingduo is offline
Default RV-12 Wiring
We are trying to Crimp Molex Micro-Fit pins ES-00047 for the trim servo wiring. Have been trying to use the tool we got from Avery . . . seems too big for these newer style micro-pins. Would love any suggestions on a better tool to use to crimp these. Directions all seem to be for the older style/larger wire and pins.
Old 11-04-2012, 06:05 PM
Peterk Peterk is offline
have you ever watched this EAA video...molex pins are crimped a little differently.
http://www.eaavideo.org/video.aspx?v=14725747001
Old 11-04-2012, 06:18 PM
We have watched this. Unfortunately, the problem is that these wires are so small that we have set up a magnifying glass to work with them. The tool we have from Avery seems oversize since it is flattening the terminals, rather than rolling them.
Old 11-04-2012, 06:50 PM
Gandalf Gandalf is offline
I have both the GC/Waldom and Sargent crimping tools and they are both too large for the Molex micro fit pins. The trim motor wire is 26 gauge. I used surgical loops and a razor blade to strip the insulation and did my best with the crimping tools.
I did a pull test and practical test using the quick connection and then touching the forward end of the wiring to a 12 volt motorcycle battery.
JAL
Old 11-04-2012, 07:37 PM
Yep . . . we got the GC/Walden from Avery and it definitely appears too large. Hence are hoping to find something that will work on these "miniature" wires . . .
Old 11-06-2012, 04:13 PM
cactusman cactusman is offline
I don't know if you have a Fry's Electronics near you but I noticed they have a bunch of crimpers for network and related gear. I didn't get one yet, but that might be an idea.
Old 11-06-2012, 05:37 PM
videobobk's Avatar
videobobk videobobk is offline
I would expect that some people might replace these with something like a 9 pin D-sub connector. After certification is complete, of course. Micro Molex seems pretty minimal as far as connectors go.
Bob
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 11-08-2012, 09:08 PM
bhassel's Avatar
bhassel bhassel is offline
Would those same people solder or crimp?
Bob Hassel
NM
Subscription Paid for 2020
Home is where the hanger is...
Old 11-09-2012, 04:52 AM
WingedFrog's Avatar
WingedFrog WingedFrog is offline
Default same here...
I was going to post on the subject having determined that the Waldom crimping tool I received in the tool kit dangerously fat for these tiny terminals. I hoped to find a solution here as some have no doubt been through the same quandary but no luck so far!
Builder's name: Jean-Pierre Bernoux
Sport Pilot
Kit # 120395 N124BX
Flying as of 9/11/2013
Builder's Blog:http://vieilleburette.blogspot.com/
EAA 1114
Old 11-09-2012, 06:13 AM
txaviator's Avatar
txaviator txaviator is offline
Radio Shack or Frys Electronics? Or I could darn near guarantee that you could buy a micro crimper online through Mouser Electronics.
Update: yep, Mouser has them....at a whopping $324 each! Gulp!
http://www.mouser.com/ProductDetail/...bTyxQVcJFPQ%3d
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
