Old 10-31-2012, 03:08 PM
bardample bardample is offline
Smile ADAHRS Location in RV-7A
I am about to install the ADAHRS for a Dynon Skyview.The mounting plate supplied by Vans is to be installed behind the baggage compartment and within 12 inches of the Dynon pitch servo for the Autopilot. Is this installation too close to ferrous coponents in the pitch servo? Has anyone had any issues with installation of their Dynon ADAHRS . Is it better to install this mounting plate from the ceiling behind the baggage compartment ? bardample Australia
Old 10-31-2012, 07:30 PM
NDrv8r's Avatar
NDrv8r NDrv8r is offline
Default adhrs mount
here's what I did.
seems to work great.
Larry Buller
RV7A slow build, Tip up, IO360 200hp, Catto 3 blade, Dynon Skyview, arinc 429, ems, SV transponder, Garmin GNS430w, Aera 560, Dynon D6.
FLYING!
Old 10-31-2012, 09:21 PM
bruceh's Avatar
bruceh bruceh is offline
I fabricated a mount up high in the back. It is well away from anything that could affect the magnatometer in the ADAHRS. Cost was nothing, since I just used scraps of material.
I ended up adding a small support for the AOA/Pitot/Static tubing in front of the ADAHRS shelf.
Poke around on my website and you'll probably find some other photos and descriptions of what I did.
Bruce Hill
2020 VAF donator
Old 10-31-2012, 10:37 PM
Thumbs up Jeff Rowlands ' bardample'
Thankyou for your great ideas. Very little risk of interference!!!
Old 11-01-2012, 05:31 AM
Walt's Avatar
Walt Walt is offline
Just don't forget, these components will need to be accessible for maintenance in the future
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
