Old 10-23-2012, 12:47 PM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
Default IPad mini
Drinking the cool aid again. Other than using a knee board (and that is even a little marginal) the iPad is a little large for the RV-8/4/3. Now there is the mini, which should fit the tandemers a little better.
http://www.apple.com/ipad-mini/overview/
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
Old 10-23-2012, 12:57 PM
TThurston TThurston is offline
Default 10,000 Feet
I watched the announcement with interest. When it was over I checked the tech specs on Apple's website, and noted "Maximum operating altitude: 10,000 feet (3000 m)". That surprized me. But I checked and it's also listed as the max altitude for all iPads.
So what does this limit mean?
Finishing -12 tail cone
-9A Empennage done, in storage
Old 10-23-2012, 01:08 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Umm, as far as I'm concerned NOTHING. I have had my iPad to 14.5K to date with no ill effects on it.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 10-23-2012, 01:28 PM
ToadMan8 ToadMan8 is offline
These devices depend on airflow around the components to keep them cool. When the air density is lower, less heat can be carried away by an equal volume of air, so altitude can cause overheating issues.
I assume this is just a design limitation; in practice there are many factors (restrictive cases, ambient temp. in the cockpit, if it's connected to external power, etc.) to consider.
Old 10-23-2012, 02:11 PM
LAMPSguy's Avatar
LAMPSguy LAMPSguy is offline
Default Airflow
I would imagine since there is no real air inlet/outlet for iPads that the air density would have very little effect other than ambient airflow over the external case. I have used mine after sitting in a closed car (150F, not on purpose) and it worked fine. I would imagine it will be fine in a RV cockpit.
Plus, American airlines just approved its use a while back. The FAA says in order for it to be approved, it must meet certain specs. One of those, for pressurized aircraft, is that it survives explosive decompression above 10,000. So, if it met all these conditions (plus Military has given go ahead to use it), then I bet it will be OK in RV cockpits.
RV-? in planning stages.
RV-14 #140050 SOLD
Permanently willing to contribute fuel for RV rides
Helicopter ATP/CFI(I)
ASEL/AMEL Commercial/Inst/CFI(I)
Aerobatic Instruction available
Atlanta based.
Old 10-23-2012, 02:19 PM
sbal0906's Avatar
sbal0906 sbal0906 is offline
Default It might just be me
But I think the last thing I would be worrying about during an explosive decompression event is whether my iPad was working or not.
Shamit Bal
http://www.flyaroundthesun.com
RV-9A
Started on wings.
Winnipeg, Manitoba, Canada
Old 10-23-2012, 02:27 PM
Jamie's Avatar
Jamie Jamie is offline
Every device Apple has produced since Steve Jobs resurrected the company from the grave have had the 10,000 foot limit on them.
Old 10-23-2012, 02:35 PM
stevemcgirr stevemcgirr is offline
Default my stupid question of the day
I ask because I'm really this dumb: Does an iPad running ForeFlight need a cellular connection, or will the new iPad mini run this app without cell connection?
Steve McGirr
RV7 N1991M
First Flight: May 18, 2013
Old 10-23-2012, 02:42 PM
moll780 moll780 is offline
you dont need cell connection for foreflight to work.
gps is needed.
ipad with cell has the gps.
wifi only will need an external bluetooth gps.
--2008 RV-9A
Austin TX
Old 10-23-2012, 02:55 PM
RVbySDI's Avatar
gps is needed.
Actually you don't need GPS for Foreflight to work either. Yes, if you intend to use it to track your position while flying it will be needed. However, if you are simply using Foreflight on the ground as a preflight planning tool it is not needed. This is true for any internet connectivity also. Again, if you are going to use it to access weather information and update data you will need to connect to the internet somehow, either by cell service or WiFi. But the overall functionality of Foreflight will not be disabled should you attempt to use it without GPS or internet connection. You will still be able to see the sectional information, airport information and even any old weather information you may have downloaded when you looked at it prior to disconnecting your internet connection.
RVBYSDI
Steve
RV9A
https://rvwings.com
