Old 10-20-2012, 10:17 AM
hjd3021 hjd3021 is offline
Default Nut Plate Question
As a first time builder I am just starting to install nut plates on the rear spar for attachment of hinge assembly. I installed the nut plates as specified in the plan. Installation was no problem. After I installed them I took one of the apporpriate bolts just to make sure everything was OK. I started to thread the bolt in by hand and it seemed to start OK but quickly seemed to lockup. Do these nutplates have a self locking feature which would explain the fact that the bolts don't thread in easy? I was going to look at them closer but did not have a chance last night.
John H
Auburn, WA
RV-12 #120672
N672JH Reserved
Empennage/Tailcone Kit Finished
Wing Kit Finished
Fuselage Kit 95% complete
New RV-12iS Fuselage Kit - in progress
http://www.mykitlog.com/hjd3021/
hjd3021@comcast.net
http://hjd3021.smugmug.com/Airplanes...7474307_JMNgxT
2020 VAF Supporter - worth every penny!
Old 10-20-2012, 10:21 AM
I think that I found the answer I was looking for in this thread. Should have read all the threads closer.
Loctite on AN3 Bolts ??
John H
Auburn, WA
RV-12 #120672
N672JH Reserved
Wing Kit Finished
hjd3021@comcast.net
Old 10-20-2012, 10:26 AM
stevemcgirr stevemcgirr is offline
Default Yes they do
I'm sure you will get other responses, but nutplates are designed to lock the bolt and they do require a pretty significant amount of torque to thread in, ie you can't fully thread them in with your fingers
There is a "tip" on the EAA website, under the homebuilders link and the videos listed there, where it is suggested that you pre-treat the nutplates prior to bolt insertion, with a tap of appropriate size. This is not a good idea, IMHO, in places where the bolt needs to stay locked, but may be acceptable when the bolt will need to be frequently inserted and removed
Steve McGirr
RV7 N1991M
First Flight: May 18, 2013
Old 10-20-2012, 10:28 AM
Again, my opinion, but the number of places where loctite is a good idea is very infrequent. In most instances, you will be using nylock nuts, star washers, or some other mechanical means of locking the bolts in place
Steve McGirr
RV7 N1991M
Old 10-20-2012, 10:40 AM
AeroDog AeroDog is offline
Default nutplates
[quote=stevemcgirr; <snip>
There is a "tip" on the EAA website, under the homebuilders link and the videos listed there, where it is suggested that you pre-treat the nutplates prior to bolt insertion, with a tap of appropriate size. This is not a good idea, IMHO, in places where the bolt needs to stay locked, but may be acceptable when the bolt will need to be frequently inserted and removed[/QUOTE]
I agree. Running a tap through the threads removes some of the self-locking capability. I do use Boelube, however.
Jerre
Empennage, fuselage and wing kits complete
Finish kit nearly complete
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2020
Old 10-20-2012, 11:05 AM
aerhed aerhed is offline
Look closely at one of your nutplates. You will see the threads are formed and then they are crimped on the outside parallel to the legs as a lock feature. Lots of past discussion here on tapping versus stretching versus leaving them alone. For me, its leave them pretty much alone on critical structure, stretch 'em where I need to, and I don't think twice about tapping some in floorboards or sometimes thin parts that get deformed from too much strong arming.
Actual repeat offender.
Old 10-20-2012, 11:07 AM
Rich_in_AK Rich_in_AK is offline
Default tapping nutplates
My general rule that I used on both my RV-8 and RV-7A is this: If a bolt goes through a structural component, leave the nutplate alone. If a screw goes through an inspection cover or other type of removable cover, then I tap it to make install/removal easier. I have never had a single screw come loose in operation and it saves a lot of screws from being ruined being stripped out with the screwdriver.
RV-8 flying, RV-7A flying, CH-750 flying, RV-14 next
Old 10-20-2012, 01:36 PM
Thanks everyone for the responses - this forum is excellent in getting answers to the questions. I will take a look at the materials referenced and a closer look at the nutplates as well. So much new stuff to learn! Its been fun so far!
John H
Auburn, WA
RV-12 #120672
N672JH Reserved
Wing Kit Finished
hjd3021@comcast.net
Old 10-20-2012, 09:37 PM
RVTrumpet's Avatar
RVTrumpet RVTrumpet is offline
I am pretty sure that the part of the nutplate that has the threads cut into it is not a completely circular shape, but just the slightest bit like an oval. This forces the bolt to expand the nutplate to the correct size. In this way, the oval shape put a force on the bolt similar to that or a lock-washer on a nut.
RV addict for life.
NOTE: The information, ideas, and opinions presented in this post are my own and not those of my employer. Build, test, and fly at your own risk.
Old 10-25-2012, 10:07 PM
waterboy2110 waterboy2110 is offline
As a general rule - any locking nuts that can be threaded by hand are worn out and should be tossed. Nutplates are locking devices.
