Old 10-12-2012, 01:08 PM
localizer localizer is offline
Default How to fix a smiley itself?
So far my "vast" experience is based on completion of a Toolbox training project and my thought is that a smiley is in the aluminum... It is a skewed rivet and a half-round impression on the sheet. Is this right?
If so, then how can the half-round impression be fixed? I see you guys say you fix this, but I think that fix is only applied to the bad rivet, which is drilled out and a new one is driven in. The smiley itself remains there. Is this all correct?
So can this be fixed?
Yuri
DA40
RV-10 - build in progress
Old 10-12-2012, 02:02 PM
rapid_ascent rapid_ascent is offline
Talking
I must admit that I'm still working my way up the learning curve on the -4 rivets. They are more difficult to set than the -3 rivets. I have found a couple of things that are helpful. First I set the pressure around 45#. Second I find that a heavier bucking bar helps. I am a solo riveter so I find that if I dont keep pressure on the head of the rivet the set will move away from the head and you will get a smiley. If you are solo riveting you have to keep the right balance of pressure on the gun versus the bucking bar. So make sure you keep more pressure on the gun. If the bar was to move away from the shop head it probably won't cause a problem unless it slides off or is angled. If the set slides off the head you will need to drill it out and start over. I have drilled out many of these.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 10-12-2012, 02:09 PM
krw5927 krw5927 is offline
Default Snap Socs
21 replies and nobody has mentioned Snap Socs yet?
http://www.yardstore.com/browse.cfm/4,5933.html
They do make you lazy though - I don't set a 1/8" rivet without them, and if I tried I'm sure it wouldn't turn out worth a darn. I seem to have little problem with each one lasting 40-50 rivets easily. Why are they so expensive? Because they're worth it!
Kurt W.
RV9A
FLYING!!!
Old 10-12-2012, 06:28 PM
johnny stick johnny stick is offline
Default see other post
See the other post... get divorced.
John
2016 dues paid since 2008
- High hopes fade on a warm hearth stone,
he travels the fastest who travels alone-Kipling
Old 10-12-2012, 09:50 PM
bird's Avatar
bird bird is offline
as others have mentioned please double check that you have the right rivet set. it should not overlap on the sides but be a little smaller than the rivet head leaving a visible edge of the rivet when placed on the head straight. The next size up looks like it fits but it kind of covers the edge of the rivet head, if you see this it is probably the wrong size. The smaller size is obviously too small and would leave a circle on the rivet head if shot.
bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 10-13-2012, 05:03 PM
BillL BillL is offline
Default All Smiles, but no Smilies . . . .
OK, i have the Avery 3x gun (bought new) and did some experimenting today. Here are my conclusions (confirming recommendations from posters here) My smilies were not on the rivet head, but on the base material.
1. Pressure is very important, 50-65 psi is a good range for -4 rivets
2. heavier sets take more air pressure: it took 5 more psi for the long offset than the short straight set.
3. Heaver, stiffer structure takes more pressure, it took +5 psi (short set) to actually set the rivet.
4. Light weight bucking bar also requires higher pressure than a heavy one.
5. Tape, masking and duct tape both provide additional clearance and cushioning, also they protect the head and it looks nicer after setting.
6. i was always holding my gun with the heel in my palm, and it really helps keep direct line of action should something bounce, but it won't bounce with the proper pressure ( low). This is particularly helpful with a swivel set for flush when solo to keep the set from walking off.
I double checked the set and it is correct per Avery site, but I still have a nagging feeling that the dimensions of the set are very critical and will discuss this with Avery to get their opinion. It seems the depth, shape and clearance to the parent material are very important. The rivet is much more loose that in the squeezer -4 set. I will post if modifications to provide some additional relief works.
Oh - - yes the "snap-socs" , i will definitely be getting some of these things.
Thanks again for all the considerate posts.
Sorry for the delay, I accidentally posted this to a parallel thread, so i copied and reposted here
Bill
RV-7
Lord Kelvin:
Old 10-14-2012, 04:39 AM
Andrew M's Avatar
Andrew M Andrew M is offline
Default listen
If you gun is hitting twice, and the bar is making contact once, then its either mass or how firmly you are holding the bar. You should be able to hear this, and I believe it's the number one cause of smiles. The structure springs under the load because it was not transmitted through to the bar, and that drives the set off the rivet, the next blow, the bar is in contact but the set isn't square, resulting in a smile. Tape, and holding square treats symptoms. The bar mass, gun air pressure, and hand pressure on both tools needs to be matched. Ear muffs, not plugs, will help you hear this if you are listening for it.
Andrew Miller
A&P, IA
-9 empennage
Wings arrived 12 JAN 13
https://plus.google.com/photos/11360...J-TuJPsmOONzQE
Old 10-14-2012, 05:33 AM
randyintejas's Avatar
randyintejas randyintejas is offline
Use Black Gorilla Tape (home depot) and lots of pressure on the gun and don’t put too much pressure on the bar. Make sure the part is VERY secure. You don’t need the socks just the tape. This fixed all my 470 problems.
RV 7
391RK Reserved
IO360 9:5:1 AFP
Slow Build
Last 90%
Tyler, Texas
Old 10-14-2012, 06:04 PM
Andrew M's Avatar
Default Light trick
Place one lights 90 degrees to where your eyes are so it both throws a shadow of your rivet gun on the sheet. The shadow will tell you if you are holding the gun square to the work in the plane your eye is not.
Andrew Miller
A&P, IA
-9 empennage
