Old 10-11-2012, 09:35 PM
pilottangocharlie pilottangocharlie is offline
Beautiful Phil! I've been anxious to see the end product. I spend countless hours reading through the G3X manuals. Someday far far from now.
Tyler
Newcastle, OK
N825TC
RV-14A #140754
Project Log
Old 10-12-2012, 07:43 AM
Strasnuts Strasnuts is offline
Default Great work
Nice job on the layout Phil,
You are going to love that panel.
I'm jealous comparing your GTN750 to my 430w
I have 265 hours on mine and it works great. No problems with the GX pilot. Mine couples automatically to the IFR external and will flip over on its own to G3X if the external fails and the G3X will automatically show all the approach and turn into emer IFR mode. Really no need for the switch. I installed a switch before they came out with this software. I sometimes use internal and sometimes use external using the softkeys.
I might be able to help so let me know if you have any questions with the use or configuration of the avionics. I wired and configured mine.
A&P RV-10 Flying 1000+ hours
SuperSTOL Flying 170 hours
Old 10-12-2012, 08:43 AM
flion's Avatar
flion flion is offline
Originally Posted by Phil View Post
Will do Patrick. I'm likely going to shoot a video of the crate and all of the work behind it. Is yours powered up yet?
No, it's sitting on my dining room table. I'm pretty busy what with Grad School and being a TA, so I probably won't get to touch my project again until the semester is over, around X-mas. But at least I get to drool over the panel daily.
Here's a small image (from my KitLog) of the back of my panel:
EAA Technical Counselor #5357
Old 10-12-2012, 08:53 AM
Brantel's Avatar
Brantel Brantel is offline
The need for the switch comes in if the G3X fails.
Everything you mentioned above requires that the G3X be operating.
Your G3X fails and all of that magic software mumbo jumbo goes away.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 10-12-2012, 02:53 PM
Azemon's Avatar
Azemon Azemon is offline
Default Nice
Beautiful...
Another beautiful day in paradise....N2977T
Old 01-20-2013, 11:03 AM
mheneck mheneck is offline
Default Another panel
First flight was in July 2012. Built by Robin Coss in Cape Town.
Old 01-20-2013, 11:19 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Default Welcome to VAF!
Martin, welcome to the good ship VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-22-2013, 07:11 AM
Default Thanks Mike
I've been observing here for years. Lots of very useful information and ideas.
-- martin
Old 02-09-2013, 07:20 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Default My Completed RV-10 Instrument Panel
Here's my completed and installed panel in my RV-10. Specifications below. All work was performed by myself
AeroSport Products Symmetric RV10 Panel, Quadrant and Sidepanels
FrontPanelExpress.com custom CNC panel inserts
LEFT PANEL:
Advanced Flight Systems AF5600
Advanced Flight Systems AutoPilot
Mountain High Oxygen 4-ip
Gretz Aero Heated Pitot Status LEDs
TCW Tech Control Servo for Oil Cooler Valve
CENTER PANEL:
Garmin GTN750
PS Engineering PAR100EX
XM Radio Onyx Receiver
RIGHT PANEL:
FData Systems GD-40 CO Detector LED
Alternate Static Air
MH Oxygen Bypass Oxygen switch
ACK-E04 ELT Remote Control
LOWER RIGHT PANEL:
PWM Dimmer for LED Switch Lighting
PWM Dimmer for Glareshield lighting
Servo rheostat control for front heat
Aerosport Products Naca Vent Controller
General items:
Honda S2000 starter push button
Aveo Engineering Air Vents
Aveo Engineering RockRack switches
Aerosport Products Flapswitch
Custom stick grips in Burlwood by CustomAircraftGrips.com
"Wood" items are Hydro dipped Aluminum and Plastic by HydroGraphicsInc.com
Rudder Pedals by Control Approach
Vertical Power VP-X Circuit Protection
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 02-09-2013, 07:35 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
Mark,
Absolutely georgous! The wood really brings it together. Nice clean layout!
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
