  #11
Old 10-07-2012, 08:05 PM
Bill Dicus Bill Dicus is offline
Default Pledge
We've used Pledge on the windscreen of our S-2A for close on 30 years with good results and no negatives. Automotive polish on leading edges has removed some of the red paint and there is white showing through. The smell of Pledge makes me think of flying, so perhaps it's what you are used to!
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
Old 10-07-2012, 10:10 PM
sandpiper sandpiper is offline
I've used lemon pledge for as long as I can remember without any problems. Don't use regular Pledge, the kind that used to come in brown cans. It leaves a buildup which is hard to get off.
I also do not like the Costco micro fiber cloth that comes in bundles. It leaves pieces of fiber behind, even when washed.
I have also had good luck with waterless car wash. Even when used on a fairly dirty windshield it will not scratch. I have also heard that Turtle Wax Ice Detailer works well but I have not tried it.
John Horn (donated for 2020)
Independence, OR
LSRM-A, CFII
Rotax Service, Maintenance, and Heavy Maintenance Trained
Building an RV-12, N7878H reserved
Flying a Flight Design CTSW
Old 10-08-2012, 11:10 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Lemon Pledge forever
As long as I can remember (60+years of flying), started using lemon Pledge on my Champ, and 15 airplanes since. Some of the "specialty" products seem easier to wipe off, but certainly not worth the cost. Leading edges are also easily treated and help keep, and take, bugs off.
Old 10-08-2012, 11:37 AM
MarkW's Avatar
MarkW MarkW is offline
In the Harley Davidson world Lemon Pledge is very common for all parts of the bike. I use it on the fiberglass fairing, chrome parts, windscreen, painted tanks and fiberglass saddle bags. Works great and no complaints about use on the windscreen. May or may not be the same material as the windscreen on the RV's.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 10-08-2012, 05:15 PM
JimWoo50 JimWoo50 is offline
Default I use my old white socks
with Lemon Pledge after one last wash of course. Not only on the plexiglass but on the metal too. Seems to make the bugs easier to wash off.
Jim Woolard C56
N9855J RV-6 Donated 2020
Old 10-08-2012, 05:37 PM
N355DW's Avatar
N355DW N355DW is offline
Default Watch out for silicone
I think, but am not sure, Pledge might have silicone, or a silicone based oil in it. If you plan on ever re-painting, depending on the product used to paint, you might have problems if any silicone is not completely removed first.
Damon Wack
RV-7 in progress
Old 10-08-2012, 06:36 PM
Sam Buchanan's Avatar
been here awhile
And it seems I recall reading where the propellant in the Pledge aerosol cans doesn't play nice with plexi. But there sure are a lot of satisfied Pledge users out there....may have to drag out that can I have in the hangar and give it another go.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 10-08-2012, 11:02 PM
nineninefour nineninefour is offline
SC Johnson says Pledge furniture polish aerosols all have silicone (dimethicone and a siloxane.). The propellant is nitrogen.
http://www.scjohnson.com/en/products...-Have-Silicone
Notably, the regular Pledge products don't list alcohols, but the non-silicone Pledge Multi Surface does, and I see that we should avoid alcohols on polycarbonate.
And before you complain too much about Plexus prices, here is the Cadillac of products:
http://sumnerlabs.com/all-products?dir=asc
John
N994 reserved for an RV-8A
Old 10-08-2012, 11:43 PM
DCat22's Avatar
DCat22 DCat22 is offline
...those prices are per case of 12.
-Rick Greer, VAF #2492
Old 10-09-2012, 09:52 PM
Originally Posted by DCat22
Quote: Originally Posted by nineninefour And before you complain too much about Plexus prices, here is the Cadillac of products: http://sumnerlabs.com/all-products?dir=asc ...those prices are per case of 12.
That would certainly be a different case. It was not clear to me from on the website, thanks for the info.
John
