Old 10-05-2012, 07:15 PM
Default Tapering The Stiffeners?
How do y'all cut the diagonal taper on the stiffeners?
I can think of several ways but I'd like to learn from your experiences. Even on an RV-3 there's lots of these things.
Thanks!
Dave
RV-3B
Old 10-05-2012, 07:19 PM
N941WR's Avatar
N941WR N941WR is offline
Marked them with a sharpe
Cut them on the bandsaw
Sanded to final size on the belt sander
Dressed them on de-burring wheel mounted in the drill press
Some guys score them and then just snap 'em off. I have never tried this as the method above worked quickly.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-05-2012, 07:30 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Default Tin Snips
Aviation Snips (Klein or Wiss) followed by the 6" deburring wheel in the drill press.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 10-05-2012, 07:52 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Repucci's method - exactly!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-05-2012, 08:35 PM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
Wow! That takes me back to the 90's and the RV-6. Thanks
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
Old 10-05-2012, 08:59 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Bandsaw all the way... still have the same saw purchased for building the RV6 back in 1991.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 10-06-2012, 05:38 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
If you scribe the taper line with a utility knife and a straight edge 3 or 4 times, you can bend and snap the excess off easily and then just clean up the edge on your scotch brite wheel. I had some AL vise jaw protectors that I used as a straight edge. You could used two pieces of AL angle to do the same. Then just clamp the stiffener at the correct angle in your vise between the angles and scribe along the top of the angle that created the scribe line. I did all of the stiffeners for my 7A in about 30 minutes and all were perfectly straight.
I used this method whenever I needed to make straight cuts on AL sheet material. Way better, faster, straighter, and cleaner than any saw will ever do. A few passes with a utility knife creates a stress line and the AL will snap like glass after a few shallow bends. Try it!!!
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 10-06-2012, 07:02 AM
380mxc's Avatar
380mxc 380mxc is offline
Paper shear
Tim Emig
RV7
As I hurdled through space, one thought kept crossing my mind - every part of this rocket was supplied by the lowest bidder.
~ John Glenn
Old 10-06-2012, 08:54 AM
aerhed aerhed is offline
Sounds like a job for the $80 throatless shear from Harbor Fright. One pull of the handle (2 seconds). Chase them with the scotch-brite wheel if you've got a bunch. If doing one at a time, pull the file out of your back pocket and you'll have it smoothed by the time you walk back to your pile.
Actual repeat offender.
Old 10-06-2012, 10:21 AM
rbibb's Avatar
rbibb rbibb is offline
If you have a table saw you can cut them on that. I used a metal cutting blade in my table say for a lot of things. I remember reading "back in the day" that some folks even used a hollow ground planer blade just for this very thing. YOu have to make a fixture out of wood to hold them at the correct angle for the rip cut you will be doing. File and/or belt sander to finish the edges afterwards...
Richard
RV-4 N144KT
