Old 10-04-2012, 05:41 PM
BillL BillL is offline
Default Firewall Fuel Penetration for Fuel Injection?
I bought an in process RV7 that had been prepared for a carb with a gascolator installed. I decided for fuel injection over the carb. It is time to install the high pressure fuel pump for the FI. I have a Vans sourced IO-360 M1B standing by. I have looked at drawing OP32 that shows a different firewall penetration point for injected fuel supply.
So . . it seems there are three options:
1. Remove gascolator, plug the hole in firewall and install the patch and hole per OP-32.
(this avoids special fuel hose and routing. )
2. Remove gascolator and install bulkhead fitting and run fuel hose over to that point on the firewall.
( can the hose be routed here?)
3. Leave gascolator in place and connect to engine.
(This has more points to leak, more pressure drop when pump is off, and more opportunity for heat collection with the additional surface area and residence time of fuel in the gascolator. Not fond of possibility of fuel delivery issues and vapor lock)
Who has done any of these and what were your results? Please Help!!
Bill
RV-7
Lord Kelvin:
Old 10-04-2012, 05:48 PM
Rupester Rupester is offline
I would do either #1 or #2, depending a number of factors. I would not opt for #3 ...simplest is best.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 10-04-2012, 05:56 PM
Jeff R's Avatar
Jeff R Jeff R is offline
I agree - 1 or 2.
Van's does not recommend a gascolator but, if you use one, use the high pressure type, not the low pressure type typically used for carb systems.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 10-06-2012, 10:33 AM
Default Thanks
. . . for the feedback, the gascolator is out. I will probably just go with the "plan" location. Next, to decide where the fuel flow meter goes.
Again, thanks for the replies.
Bill
RV-7
Lord Kelvin:
Old 10-06-2012, 10:38 AM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
Option #1 and use the doubler for the new location per OP-32. The FWF hose then fits right out of the box saving you from making a custom one or finding on that is the proper length...
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
Old 10-13-2012, 06:09 AM
Grezdlitn Grezdlitn is offline
Default OP32
I'm in the same boat. I was going to put a bulkhead fitting thru the doubler that Van installed for the facet pump on the carbed install and call it good.
I'm unfamiliar with the plan designation OP32. Is this in the standard plan set?
Mark
Old 10-13-2012, 05:18 PM
I did as Grezdlitn did. Works great, but keep the opening as high in the doubler as you can. It makes the piping connection on the aft side of the f'wall easier. that doublerr is small enough, there's not a lot of room to elbow the fuel line up from the cabin floor.
Terry Ruprecht
