Old 10-04-2012, 10:30 AM
Kenny Gene Kenny Gene is offline
Default RV-10 Andair fuel selector valve setup
Guys,
I'm going changing out the original Van's fuel selector valve for the Andair and I'm not for sure which Andair valve and extension is needed, I really don't want to tear down my tunnel to measure to order, so if someone has installed the Andair fuel system and has the numbers, Please post or PM.
Because of the time and freight from Andair in ENGLAND, I want to measure twice and cut once, however, it appears I'm too lazy to dismantle my tunnel to measure myself,, well,, at least I'm honest abut it!!
Many thanks.
Kenny Gene
Rv 10 484TC 205 hrs
Old 10-04-2012, 11:22 AM
rleffler's Avatar
rleffler rleffler is online now
Originally Posted by Kenny Gene View Post
Guys,
The short answer is yes you'll need the extension. How much depends on how old is your fuselage kit. For the current kits you'll just need 3-4". The older kits the valve was mounted higher in the tunnel. A 6" extension should be fine.
As to which valve, you can use the wizard on their site to determine with type of connections you prefer. They have quite a few. I don't have the part number I ordered handy.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 10-04-2012, 01:21 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
I ordered the EFS20x3-T as I wanted the one with a full 180* turn between left and right.
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 10-04-2012, 01:30 PM
Wayne Gillispie Wayne Gillispie is offline
Kenny,
Curious if you have a leak or something wrong with it? I keep a spare valve with fittings ready to go at the hanger. No problems so far at 85 hrs.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 10-04-2012, 06:08 PM
My current kit valve is not leaking, it's jus I liked the smooth action of my Andair fuel valve in my 7a. My opinion is the kit valve is "clunky" and after 200 and some odd hours, I'm going to change it.
Thanks for the replies.
Kenny Gene
Rv 7a 294TC AWC 9-07 (690 hrs) sold 11-11
Rv 10 484TC AWC 10-10 (200 plus hrs)
Old 10-04-2012, 07:27 PM
N427EF N427EF is offline
Default No extension
Why bother with an extension?
Since you are replacing Van's valve which is mounted to the lid on the tunnel why would you you want to mount the Andair lower in the tunnel with an extension?
Mine is mounted to the lid and this way there is room to accommodate the heater hose for the rear seats.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 10-05-2012, 01:28 PM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
Same here, works great. Just route your heater hose below the valve, making sure the hose doesn't rub on the rudder cables.
-Rob
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 10-06-2012, 06:57 AM
blahphish's Avatar
blahphish blahphish is offline
-Rob
We installed our Andair higher up too. We put some fire-sleeve around the fuel lines where the scat tube passes through to protect them. You may consider purchasing a swivel T fitting from vans: http://vansaircraft.com/cgi-bin/stor...t=F-Swivel-Tee
More resources:
http://www.deemsrv10.com/37-2&3.htm
Brian Unrein
RV10 N42BU 900+ hours!
First flight 6-16-12
https://N42BU.com
