  #11
Old 10-03-2012, 10:39 AM
douglassmt douglassmt is offline
Default Geoff's
I used Geoff's, and I had a pink cabin top - love his stuff. I went to the trouble of glassing it in and filling the transitions all around the edges to make it look good so I didn't need a headliner (see pics). The OHC fit really well with very little cutting/fitting; most of the work for me was making the transition look good around the edges, which you wouldn't need to do if you are using a headliner.
I put a lot of lights in mine, and love them when I need them, but don't use them very often - mainly when I'm starting up in the dark for an early departure, and the occasional night flight. They are all LED (of course) and include some simple "dome" lights for overall cabin lighting, red map lights for the front seats, and indivdual "eyeball" reading lights for all four seats. All are dimmable. I used the cheap black eyeball reading lights but I think I would use the fancy ones with the dimmer on the light (Sean Strasburg used these) if I did it again.
I used the Stein air vents (great) AND I added Geoff's NACA vent controller because you just can't get all the leaks out of it and it's really nice to be able to shut off all air to the OHC in the winter.
You will need to figure out how to butt the OHC up against the aft bulkhead (top half) so that it seals, but I just did it with a little piece of rubber seal just like the gap cover seal that goes under the HS.
One other thing. The OHC is great for running wires as well. I used the tube over the glareshield to run cables to the three GPS antennas I have up there: two external and one internal to the console. I also ran the power/ground wires for the LED lights. Without an OHC it would be real hard to put antennae on the cabin top.
My $0.02
Bryan Douglass
=VAF= 2022 dues paid
RV-10 N242BD
Old 10-03-2012, 01:16 PM
ddnebert ddnebert is offline
Default GM overhead
I installed the Chevy S-10 overhead console, bought on eBay used for $35 plus shipping. Added the missing OAT probe, and it now has a compass readout and temperature in LED, four point lights, an overhead 'baggage' light over the rear seats, and slots for sunglasses or something else.
No air vents, but honestly, other than taxiing around the grass at Oshkosh in July, I haven't found the need for extra cooling in the -10 to warrant the weight and expense of AC.
Doug.
Doug Nebert - RV-10, #40546 (SB), started 2/2006, low compression O540 with older CS prop, 375+ hours on Hobbs. Flying since August 2010. Based KONP, Newport, OR
Old 10-03-2012, 01:37 PM
Aerosport1's Avatar
Aerosport1 Aerosport1 is offline
The Aerosport carbon fiber overhead only weighs 2.25 lbs The fiberglass ones
of the past weighed 8-9 lbs. That is a big savings on weight. Also the vents in the overhead are really nice. They do provide some air while taxiing and when in flight really make the cabin comfortable for all passengers.
Geoff
Geoff Combs
RV-10 N829GW 865hrs
1940 Piper J3 Cub
Rans S21
Old 10-03-2012, 01:44 PM
Default Ditto on the air
I agree that the extra air flow you get from the OHC is a really nice feature for the -10. Living in northern climes I virtually never feel the need for A/C but I spent a lot of time in the south and midwest this summer and the extra air you get at low altitudes or on the ground is a big plus. Having the ability to put air on someone's face also helps with the occasional motion sickness.
Bryan Douglass
RV-10 N242BD
Old 10-03-2012, 01:48 PM
woxofswa woxofswa is offline
I used Geoff's unit with Stein's vents for my airflow systems air conditioning installation. I attached it with some recessed stainless screws and pro seal.
Very happy with the results.
Myron Nelson
Mesa, AZ
RV-10 N24EV
KITPLANES Contributing Editor
Old 10-03-2012, 01:55 PM
Janekom's Avatar
Janekom Janekom is offline
With regards to the pics of Geoff's OHC - Is that a handle that I see in the back in the recess?
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2021 WITH A SMILE
Old 10-03-2012, 02:17 PM
Default Yep
It's a handle for the passenger on the baggage area lavatory to hang onto in lieu of a seatbelt...or a coat hanger.
Bryan Douglass
RV-10 N242BD
Old 10-03-2012, 05:36 PM
flion's Avatar
flion flion is offline
Wait, what? Baggage area lavatory? What plans section is that? I think I'm missing some parts!
EAA Technical Counselor #5357
Old 10-03-2012, 05:45 PM
Default Add on
It's a custom add on I did. Just a big door in the floor that opens to the outside and a toilet seat bolted to the baggage area floor. And a roll of toilet paper mounted nearby
Maybe we can get Geoff to make a carbon fiber toilet seat...
Bryan Douglass
RV-10 N242BD
Old 10-03-2012, 08:15 PM
eric.kallio eric.kallio is offline
Default second that
Originally Posted by Auburntsts View Post
Understatement of the year so far!!!!! Let's put it this way, I'm working on my doors and at this point really don't know what all the fuss is about (I'm not kidding), mainly because campared to that Accuracy Avionics console, the doors are a piece of cake.
I have the Accuracy Avionics overhead and center consoles. I went there 5 years ago because it was just about the only option for fiberglass at the time. Boy did that bite me in the *** later. What Geoff Combs is selling is light years beyond what I had installed in fit and finish. You can't go wrong.
Eric
Eric Kallio
RV-10
N518RV... Flying
