Old 10-02-2012, 11:12 AM
RV6_flyer's Avatar
Default Night flying
How does your EFIS affect your night vision? What do you do to adjust the brightness of your EFIS for night flight? Is there one adjustment to adjust everything in your cockpit to the correct night brightness?
Please let us know which brand you are using for the above questions.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 10-02-2012, 11:23 AM
Ironflight's Avatar
VAF Moderator / Line Boy
In both the -8 (GRT EFIS) and the -3 (G3X), I essentially turn the brightness almost all the way down for truly dark night flying.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-02-2012, 11:35 AM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
A Dynon SkyView goes from 1350 nits all the way down to 0.2 nits. A D100/D10 goes down to about 0.4 nits.
These dim levels require you to be in a dark room for a few minutes to even tell if they are on. We got these requirements from Boeing who has a 0.4 nit spec for night flight.
In our experience, you need to go this dim for something to work for real night flight. At one point the D10 "only" went down to 0.8 nits and we got some complaints. It's easy to build a really bright screen that also blinds you at night. In our opinion, if in a lit room you can still see the screen at all when it's all the way dim, it's way too bright to be used on a dark night in the middle of nowhere.
The D10/D100 must be manually dimmed unless you have an HS34 or an AP74. SkyView has a light sensor built in and can be manually as well. In both cases, if you have multiple screens, adjusting one screen adjusts them all at the same time. It is possible to use an output from the SkyView to dim other cockpit equipment in tandem.
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 10-02-2012, 11:48 AM
Wayne Gillispie Wayne Gillispie is offline
Adjust GRT, Dynon D6, Garmin 430w and G327 buttons manually, everything else is automatic. Cover LED warning lights with strip of window tint/velcro buttons.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 10-02-2012, 11:55 AM
jbagley's Avatar
jbagley jbagley is offline
As an electronics hobbyist, i'm curious, where do you (Dynon, AFS, etc..) source your screens? Or is this a trade secret? I've played with a few over-the-counter screens designed for automotive applications, but they aren't anything near the quality of the Dynon or AFS screens.
James Bagley Jr
RV6A flying
RV6 #2 tail done and wings done
Old 10-02-2012, 12:16 PM
BobTurner BobTurner is online now
GRT screens I have wired to a dimmer, along with autopilot lights. They can be controlled with on screen buttons if you want to go that route.
D6 controlled with its buttons. Another dimmer for glare shield lighting.
I let the other avionics set themselves with their photocells.
Old 10-02-2012, 12:34 PM
Jbagley,
Dynon's screens are consumer screens out of netbooks, but they are custom brightened and anti-glare coated, so they are not commercially available in the way you see them in a SkyView
The dimming circuit we use to get both the brightness and dim levels we have is a totally custom circuit that I've never seen in any commercial LCD screen. Most LCD's have maybe 100:1 dimming ratios, while you need 2000:1 for avionics.
Dynon Avionics
425-402-0433
Old 10-02-2012, 04:30 PM
scard's Avatar
scard scard is offline
...And it is still way too darn bright on the GRT products (H1 WS & HX) in real darkness. I've resorted to covering displays with a piece of paper at night on a number of occasions as apparently they are really difficult to dim low enough and still have a stable image.
Scott Card
CMW E-Lift
Old 10-02-2012, 05:07 PM
I have not had any problem with the HX's. You can always put a piece of windoow tinting over them temporarily. How much do most of us fly in pitch black darkness?
DCat22's Avatar
DCat22 DCat22 is offline
+1
In the rentals I fly I always carry post-it notes to mute the inevitable non-dimmable (or poorly dimmed) lights that become blinding beacons at night. I keep the steam gauges just visible... And then you can see outside so much better, what was once "just black".
Same thing driving IMO. My car has black electrical tape in a few key spots for the same reason. Why in the world do I need a bright green non-dimmable light to tell me my headlights are on?!
-Rick Greer, VAF #2492
