09-27-2012, 09:02 PM
Front Panel Express Discount Code
If anyone is considering using Front Panel Express ( http://www.frontpanelexpress.com/) to design and cut their panels or other parts, I have a 20% discount code I can pass on from my recent order. Just let me know if you are going to submit an order soon and I'll send you the code I have.
CharlieWaffles - But you can call me " Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
09-28-2012, 11:02 AM
Pix?
Hi Mark,
Did Front Panel do your entire panel, and if so would you have any pix to share?
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
09-28-2012, 12:32 PM
I would like it. Also like to know lots of things.
I won't be ready to cut my panel for a few months, but am interested in FrontPanel Express. I had looked at them earlier, but had not gotten that close to cutting that I had fully researched them and committed to them.
What did the total come out to for the panel inserts?
Did you find the process easy?
I have a Aerosport panel as well, but not the symetric one.
09-28-2012, 01:00 PM
I don't know what Geoff charges, but he does cut out the inserts upon request.
His other business is a custom modeling shop, so there isn't much in can't do. Whether the price is right, is something that only you can judge.
09-28-2012, 01:15 PM
Bill,
I see you work in IT (as do I) so I don't think you'll have any problems with FrontPanelExpress. You can see the pricing for panels within the software - there is a Pricing option on the menu. The charges are per line of text, hole, colour fill, engraving tool change, etc.
This is from my experience using the German outfit partnered with FPE.
I just did small sections to go around switch and CB panels etc.
The standard options allow you to specify rectangular panels but you can do non-rectangular panel (which I have done) if you supply your own DXF files. I'll try to post some examples later.
I've been well impressed.
Steve Hutt
West Sussex, UK
RV-7 G-HUTY (not flying yet)
( Tip-UP / TMX-IO-360-M1B / Hartzell 7497-2 / 1x LSE PLASMA III / Dual AF4500's / AF-Pilot AP / 695 )
09-28-2012, 02:03 PM
Steve Hutt
West Sussex, UK
09-29-2012, 03:12 PM
I am away from the shop, but I will post pictures of the panel when I return. I had the DXF files for the panel inserts for the Aerosport products and then made dxf files for the AFS panel, MH oxygen 4ip, AF-Pilot. The rest of the items (Garmin GTN, etc..) are all square shapes and easy to work with. They can also do in-fill engraving which I originally looked at doing, but they do have a limitation of how you can powder coat and engrave that wouldn't work for me.
RV-10
N928MT
Build Project Site
10-06-2012, 06:16 PM
I just posted my blog for the panel inserts ( http://myrv10factory.wordpress.com/2...nics-in-panel/). My inserts are unfinished and un-engraved as I will have that done once I get everything mounted properly. I did forget to have my LED status indicators drilled above the MH oxygen panel so I will have to do that manually. Otherwise everything worked out very nicely.
RV-10
N928MT
Build Project Site
11-15-2012, 10:57 AM
I have a new discount code if anyone needs it for their panel work. Just PM me.
RV-10
N928MT
Build Project Site
