Old 09-24-2012, 05:19 PM
rulmen rulmen is offline
Default Vans Site
Anyone know why Vans site makes no mention of RV-6's anymore? Are they signaling that they are moving away from supporting the model?
N128RU Reserved
RV-6A 50% Complete
Old 09-24-2012, 05:25 PM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
The empannage kit hasn't been available for quite some time. I'm sure they'll make parts for already ordered kits, but they aren't selling new ones.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
Old 09-24-2012, 05:49 PM
John R. Graham John R. Graham is offline
The RV-6 order form is still there, just without the empennage kit as an option. I believe the empennage kit option disappeared shortly after the RV-7 was introduced.
- John
Old 09-24-2012, 06:03 PM
Default RV-6 Vans Site
But they have virtually removed all references to the -6. Looks like I better get done before parts are no longer available.
N128RU Reserved
RV-6A 50% Complete
Old 09-24-2012, 08:00 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
The RV6 info is still there, just not linked from any menu or other pages. You have to go directly to the RV6 URL: http://www.vansaircraft.com/public/rv6.htm
Neal Howard
Airplaneless once again...
Old 09-25-2012, 07:23 AM
Perhaps there was a technical problem with the new site in that there was not room for all the models in the bar at the top of the page.
One model had to be removed when the 14 was added, as you can see, that box is crowded with airplanes.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 09-25-2012, 09:29 AM
JonJay's Avatar
JonJay JonJay is offline
You can make any RV3, 4, or 6 part you need. The plans cover all of the details to fabricate them. So, if Van's ever quits producing parts (by the way, you can still get RV6 empennage parts, they just don't "offer" the kit directly), you can make them yourself or any competant sheet metal shop could fab them up for you.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 09-25-2012, 10:49 AM
WenEng WenEng is offline
Default You can navigate to RV-6/6A page from Vans home page..
From the home page click the News and Events tab. Under that tab is the Archives tab. Select that and you will see the RV6/6A link.
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
Old 09-25-2012, 11:03 AM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
When I built my -6a they had already switched it over to the 7 tail which is why you see some of the later 6's with the "tall" tail.
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 09-25-2012, 05:57 PM
Default -6 Info
Thanks all!
N128RU Reserved
RV-6A 50% Complete
