Old 09-15-2012, 08:56 AM
db9469 db9469 is offline
Ed-Use CR3214-4-2's in the two verticle holes. These are 1/8" diameter rivets with reduced heads (same countersink as -3 solids) so you'll need to upsize the holes to #30. Use CR 3214-4-4 in the hole common to the longeron. Same thing applies. You will need to upsize the hole to #30. You can pull them with a standard set of pop rivet pullers.
Old 09-15-2012, 11:30 AM
N9331v's Avatar
N9331v N9331v is offline
Hey thanks for the rivet info. I just finished up with my canopy and was getting back to that section this weekend.
Ed
Ed Martin
Bluskydtl
RV7
DKB
Donations 1/19 & 6/19
