Originally Posted by wrongway john
Van's article on heavy wings says one can always use a wedge under the aileron if the squeezing didn't work out. It didn't say which aileron. Would it go on the aileron with the heavy or light wing?
To answer my own question:
I found out through a lot of searching on this site, that you place the wedge on the underside of the aileron on the lighter wing, in case others want to try this, and if you don?t want to squeeze the aileron. Not sure why Van's article didn't state this.
Anyway, my problem is solved, and it was so easy. First, I tried the aileron squeeze on the light wing which is my left. I only did about nine inches worth, as other recommended, just go slow and try not to overdue it and not do that long of a span at first. I didn?t notice any effect the first time.
The second time, I squeezed slightly more, but this time, it seemed to make my heavier wing (right wing) even heavier. With a passenger and fuel equal, I have to use all of my trim now, along with some light stick pressure that I hadn?t had to do before. Not sure what gives.
I tried to measure my ailerons thickness to see if I could quantify it a bit. I took some dial calipers and set it to .300. I gently slid it along both ailerons. With the heavy wing, the calipers would go in about 3/8th?s of an inch. On the light wing, only about an 1/8th of inch. This does seem to indicate my light wing aileron is thicker, and needs to be squeezed. After the results of the first test, not sure I wanted to try it again though.
But as I was saying, while reading through threads, I noticed another who said he used the wooden wedge, but put it on the underside of the lighter aileron. Mine already had a wooden wedge that was 4 and a half inches long that was placed on the heavy wing!? Go figure. I decided, I would take it off, but didn?t expect much. But wow, it did the trick! Finally, she flies true and straight, and ball is in center. With full fuel on both tanks, and just me, I had to use a little bit of trim on the right, which seems about right with just me in there. I?ll do a passenger with about my weight next, to see how close it is, but what a major improvement already. Why in heck that wedge was on the heavier wing, I have no idea, and don?t understand at all why it was ever placed there.
Just hope this helps others that may be experiencing similar problems.
