Old 09-08-2012, 11:24 PM
AlphaSierra85 AlphaSierra85 is offline
Default Considering building an RV-8
I am first time builder considering an RV8. I am looking for an aircraft that is both capable of local sport flying as well as the occasional cross country trip. I would primarily be flying solo. Any thoughts? Is there a better project to build for my first airplane?
Tony
Old 09-09-2012, 04:24 AM
Ettore's Avatar
Ettore Ettore is offline
F1 Rocket?
Ettore ”Hector“ Bellini
B737NG Senior First Officer
RV-8 planned, to become real sooner or later.
Verona, northern Italy.
Old 09-09-2012, 04:39 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Default Welcome
Tony
Tony,
Welcome to VAF! I'm sure you will get many opinions in response to your question. All of the Van's aircraft are wonderful airplanes and can be built by anyone with a modicum of skill. It is a learning process and you will build upon your skills as you go. Which model to build depends on your mission. The -9, -10 and -12 are not aerobatic. The -3 has only one seat. The -4 and -6 are a bit more difficult to build as they do not incorporate the matched hole technology of the later models, however there are some great deals to be had on used -4's and -6's if you want to go that route. The choice of side-by-side or tandem seating is a hot topic. If you travel with a significant other, a side-by-side -6 or -7 may be preferred unless you are on the large side as the shoulder room gets a bit tight. (That's where the -14 comes in; lots of shoulder room.) If you plan on doing a lot of formation and/or aerobatics the -4 or the -8 may suit you better. The centerline seating and unrestricted view make them well-suited.
After hearing all the opinions, make your own decision.
Now, do you want to hear about conventional gear versus tailwheel; constant speed versus fixed pitch,etc? Stay tuned...
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 09-09-2012, 04:59 AM
pierre smith's Avatar
Default Yep
Smokey gave you good advice, as an -8 owner.
The beauty of the -8 is also its 200 MPH cruise capabilities and more room for the Bubba sized guys.
...oh, and a big welcome to VAF!
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 09-09-2012, 06:51 AM
Skykingbob's Avatar
Default Welcome to VAF
Tony....Welcome to VAF!
My love affair has been going on with the RV-8 for 16 years....although I have only recently become an actual builder! My reasons for the -8 were: afraid I would be lacking shoulder room in side by side (big shoulders from body building of course). I figger that I can remove the stick in the back when my wife and I travel and she will have all the room in the world to read or ????
It really is a personal choice.....best wishes!
YOL BOLSON!!!
Bob "Skyking" Corriveau
RV-8 QB Reserved N212KB
ATP
CFI/CFII/MEI
Old 09-09-2012, 08:40 AM
Berchmans Berchmans is offline
Default Good choice
Welcome to the group...I am building an 8...first one...won't be the last...
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2020
Old 09-09-2012, 09:06 AM
sailvi767 sailvi767 is offline
Originally Posted by Ettore View Post
F1 Rocket?
What is the status of the F1 rocket kits? I know the website is still up and it appears the kits are for sale however my understanding is the factory is shut down. Does anyone have a update?
George
Old 09-09-2012, 08:32 PM
chrispratt's Avatar
chrispratt chrispratt is offline
Super Moderator
Tony
Tony:
Your situation sounds very much like mine when deciding what to build. I chose the -8 because I usually travel solo, wanted a good local VFR sport plane, a taildragger plus some cross-country and sport aerobatic capabilities. I could talk for hours about the -8 (most -8 people can), but I'll cut to the chase -- this is an ideal airplane for what you want to do.
It's a great pattern airplane as it flies slow very well.
It's a great taildragger because it has excellent forward over the nose visibility even when taxiing (no S turning required) and has a large rudder to help give you precise control on takeoffs and landings. It's a well mannered taildragger.
Sport aerobatics are a pleasure due to the well harmonized controls.
And it's a great cross-country airplane because it's speed enables you to go so many places quickly (and back home again the same day if need be). My trip from Dallas (52F) to Oshkosh each year (775 nm) is less than five flight hours. The -8's two baggage areas offer plenty of space for the solo traveler and enough for two if you plan accordingly.
One caveat, I've found I underestimated my use of the plane for cross-country. I've done much more than I thought I would and if I had it to do over, I would have equipped the -8 for IFR right out of the gate.
As you can tell, I'm a fan of the RV-8. Based on the needs you stated in your post, i think it would be a great choice for you.
Chris
Chris Pratt (2020 VAF DUES PAID)
RV-8 Flying, 850+hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Northwest Regional, Aero Valley, Whatever, TX)
Old 09-09-2012, 09:26 PM
Toobuilder's Avatar
Tony,
It's hard to go wrong with a -8, but I'd suggest you get some time in one to see if it suits you. I fly one quite often and have a bunch of long cross countries in it as well as plenty of local goofing off - and I can say that I once was seroiusly considering one, but it's probably out of the running now. Don't get me wrong, it is a very good airplane - but some things rub me the wrong way. The bottom line is that nobody on the internet can tell you one way or the other - get some seat time and go from there.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 09-10-2012, 04:46 AM
madhun madhun is offline
Originally Posted by ronschreck View Post
Tony,
All sound advice but are Tail Dragger & Conventional not one & the same or did I miss the joke?
