Old 09-05-2012, 06:26 AM
joedallas's Avatar
joedallas joedallas is offline
Default Jab 3300 with fuel in wings
Oren's RV 12 now has about 10 hours of flight time with the Jab 3300 and fuel tanks in the wings, all weight and balance problems worked out fine.
A few adjustments to the cooling ducts are in progress and we will report the performance when the numbers are all confirmed.
First Flight July 11
Test Pilot Andy Hostetler Reporting a rate of clime of about 1000' fpm Engine running very smooth and aircraft handling great.
Up date 09/15/12 total time 18 hours
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 09-05-2012, 07:42 AM
mtnflyer mtnflyer is offline
Default Thanks---rv 12
Keep up the good work and let us know how things progress.
Old 09-05-2012, 08:04 AM
DanBaier's Avatar
DanBaier DanBaier is offline
With the 12 being okay for E-AB, this could be a real winner.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 09-05-2012, 08:13 PM
splitty splitty is offline
Smile Jab 3300
Good to hear..! Look forward to more performance Figures then!!
Old 09-15-2012, 04:35 AM
orenjr orenjr is offline
Default Jab 3300 update
We now have approx 18 hrs on the jab 3300 rv12 . We are working on fine tuning the carb and cooling ducts. As of now we are seeing very good cooling with cht's of approx 300 (very good ) We are experimenting with the bing jetting for max performance and economy. Will update with speeds and climb rate when we get it fine tuned.
Oren
Old 09-15-2012, 06:30 AM
Peterk Peterk is offline
Joe and Oren,
Who did you use for your cowling build? That engine obviously requires special attention to the cooling needs.
Old 09-15-2012, 01:51 PM
E. D. Eliot E. D. Eliot is offline
Default Beautiful
Cowling is beautiful - really nice job. Certainly improves the looks of the RV-12.
I applaud the efforts to power the 12 by 'other' engines. Will be following this thread closely. Well done!
Old 09-15-2012, 01:56 PM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
I noted the distance from the nose wheel to the prop. On the Viking, even with a 4 inch extension, we are still close to clipping the nose wheel with the prop.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 09-15-2012, 08:12 PM
Default jab 3300 cowling
I got the cowling from Jabiru USA.It is the same one used on there jab 2200 . 3300 just sets back further. Prop is at same location. With Joe's help I put the battery in the tail cone. Joe feel free to post the picture of the Battery mount. Oren
Old 09-16-2012, 04:37 AM
Default cooling
Pete in regards to the cooling.
I put the oil cooler on the oil pan and added the chin scoop.Oil cooling is perfect.
Head cooling is not a problem at all. All you do is follow Jabiru cooling duct instructions per Jabiru USA.
Oren
