Go Back   VAF Forums > Main > Reviews
  #11
Old 08-31-2012, 07:13 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Originally Posted by Flying Scotsman View Post
ETA: On a side note, assuming one used their own ropes, and I'm sure to open a religious war here, what's the best method for tying down to a hard point? I.e., what combination of knots on which point (plane and hard point) do you use?
In my experience, people just seem to tie random knots until they think the rope is "tight" and TLAR, but there must be at least a couple of recommended methods for tying down, no?
"Random Knots..." - see, this is what happens when parents emphasize Soccer over Scouting....no one knows how to tie good knots anymore!
A bowline gives a good solid connection to a hardpoint on the ground, and I am a fan of the taught line hitch (which is a variation on the classic half hitch) coming down the standing part of the rope after looping through the aircraft attachment point.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-31-2012, 08:34 AM
RVFlyer RVFlyer is offline
Default Knots
As my father-in-law says...."Don't know a knot? Tie a lot." He was a very active cave diver so he knows plenty of knots. I've enjoyed learning some of them from him.
Actually, as an airport manager, I've seen plenty of different knots to tie down planes. While some wouldn't hold very long in a Kansas thunderstorm, some are just amazing. I've spent more time than I care to admit, out on the ramp, trying to reverse engineer a few of them.
Tom Chandler,
AOPA Regional Manager - Central Southwest
RV-4 bought it, sold it, bought it back, storm totaled it
ATP, CFII
Old 08-31-2012, 08:46 AM
SilverEagle2's Avatar
SilverEagle2 SilverEagle2 is offline
Nice report Paul and Louise.
You should polish them though
Jason Hess
N777JH - Reserved
RV-7 - Builders Log Tail complete, wings nearly done, starting fuselage!
RV Factory - Complete sans floor coating, Slideshow Here
People are not excellent because they achieve great things; they achieve great things because they choose to be excellent.
Gerald G. Probst, Beloved Grandfather, WWII B-24 Pilot, Successful Businessman
Old 08-31-2012, 11:03 AM
scsmith scsmith is offline
Default carabiners?
I bought these, and spent an hour at REI, and could not find a 'biner that fit, except for a small aluminum one.
I am worried that the little aluminum carabiners, which are made for clipping gear to your harness, not for clipping yourself to a rope, are not strong enough for tie-downs.
So, for now, these pretty tie-downs are sitting in my tool box.
Also, the holes in the tiedown "ring" remove so much metal that the tiedown itself is not as strong as I think it should be. The web site says they yield at 1500 lbs. That's probably good enough.
If I could find some small stainless steel carabiners that fit, I guess I would try them again.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 08-31-2012, 04:08 PM
Greg Arehart's Avatar
Here's a photo of one that I made a few years ago (they're painted now):
Good for a half-knot or so over the round rings if you plug the hole when flying!
Greg
Greg Arehart
N 7965A
Old 08-31-2012, 04:21 PM
You'll need those 'biners, though. The sharp edges will reduce rope strength if you tie them directly.
Dave
Old 08-31-2012, 05:24 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
There is an alternative to the caribiner. From my local Lowes':
Old 08-31-2012, 06:11 PM
Default yes, although kind of fussy
Yes, that is a very good solution, I use shackles like that on the halyards on my sailboat. But it is a bit fussy to have to put those on first, then tie the rope through it. 'Biners are so quick - just wish they made one small enough that was strong enough.
They do make shackles with a spring-loaded 1/4-turn latching pin, but they also are not strong enough.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
Old 08-31-2012, 06:47 PM
N941WR's Avatar
N941WR N941WR is offline
Default Just remember...
If you are leaving the tie-down rings in the plane, depending on what they are made of they may react with the aluminum bracket they are screwed into.
I have seen one RV-10 that has left the ?stock? tie-down rings in place and the corrosion is evident and the plane isn?t that old.
That is the one reason I always remove my rings.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-31-2012, 09:06 PM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
Paul
There's an app for that (Grog Knots). I never can remember knots. Also
The biner was a great idea. Spent some time in REI myself recently.
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
