Old 08-26-2012, 08:45 AM
TXFlyGuy TXFlyGuy is offline
Originally Posted by chaskuss View Post
Myron,
This would be a much better choice, if 100 LL will be used. It has the correct "ash-less dispersant" additive package.
Charlie
Thank you, Charlie!
Old 08-26-2012, 09:13 AM
rocketbob's Avatar
You could run Mobil 1 if you take care of the ring and piston clearances. When was the last time you've seen a gasoline car engine oil turn black?
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 08-26-2012, 09:20 AM
Never seen black oil. And I change oil (Mobil One) every 7,500 miles on my wife's Explorer, 5.0 V8. Been using Mobil One for over 160,000 trouble free miles. And the oil consumption is minimal today. For the first 100,000 the engine did not burn a drop between changes. Now it will use a quart every 7,500 miles. I attribute this to the oil and the religious break in procedure we employed when the engine was factory new.
Old 08-26-2012, 09:59 AM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default There may not be a good answer
As I now understand the question, it relates to the best oil for a Chevrolet engine used in an airplane. Let's admit that there is no oil on the market that was formulated for this application.
The obvious choices are:
1. Aero-Shell or Exxon-Mobil partly synthetic.
2. Mobil-1 or comparable synthetic for automotive
3. Whatever is the best oil for marine gas engines which often use automotive blocks.
Given that marine applications of car engines are meant to run long periods at high power settings and car engines are not, that would be worth a look.
I don't want to start a war over additives, but it's worth considering a non-synthetic car oil with a really good, patented oil additive which I will only name in a PM or email. I ran my 78 Toyota >230k miles on that and the cam lobes were still within specs when I sold it. That would solve part of the problem with lead. Of course, you still would have plug fouling and such.
Aviation oil, IMHO, is a poor choice simply because it is not designed for that kind of engine. When Mooney had a Porsche engine option, it used car oil, IIRC. AvOil does not contain, the last I heard, the comparable anti-wear package(s) because we don't want deposits in the combustion chambers which might encourage detonation at high, continuous power settings. Aviation oil is also higher in viscosity than what is normally used in an auto engine. The clearances are likely the reason, but the idea of running higher viscosity oil than that for which the engine was designed needs some careful thought, too.
A related question that bears careful decision making is the fuel to be used. If the fuel does not have lead, then the lead issue goes away. However, I don't mean to start a war over car gas vs. av gas. Everything about that has already been written. That said, car engines and even marine engines are no longer designed to run on leaded fuel. Of course, cars and boats don't have the same issues with altitude, seasonal blends and so on.
So there may not be a really good choice in this situation, but given that the decision was made to use an auto engine conversion, then the fuel and lube questions must be decided. It may come down to the least-bad choice.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 08-26-2012, 04:42 PM
jetdriven jetdriven is offline
i ran my 2005 Honda Accord V6 33,000 (thirty-three thousand) miles one one Mobil 1 oil change and sent it in for oil analysis to Blackstone. Viscosity, metals, everything was within limits.
Byron
1977 Mooney 201
Houston, TX
Old 08-26-2012, 05:32 PM
RV6_flyer's Avatar
Default Mobil Aircraft Engine Oil
The following is a copy paste from:
http://www.lieffcabraser.com/defecti...aft-engine-oil
  • Issue: Defective product
  • Result: $12.5 million settlement
  • 1995
Gross v. Mobil
Lieff Cabraser served as Plaintiffs' Class Counsel in this nationwide action involving an estimated 2,500 aircraft engine owners whose engines were affected by Mobil AV-1, an aircraft engine oil. Plaintiffs alleged claims for strict liability, negligence, misrepresentation, violation of consumer protection statutes, and for injunctive relief.
Plaintiffs obtained a preliminary injunction requiring Defendant Mobil Corporation to provide notice to all potential class members of the risks associated with past use of Defendants' aircraft engine oil. In addition, Plaintiffs negotiated a proposed Settlement, granted final approval by the Court in November 1995, valued at over $12.5 million, under which all Class Members were eligible to participate in an engine inspection and repair program, and receive compensation for past repairs and for the loss of use of their aircraft associated with damage caused by Mobil AV-1.
For some old but good reading on oil, try this link.
Added another link:
http://www.avweb.com/news/news/182891-1.html
For safety reasons, 100% synthetic oil should never be used in an aircraft engine that uses lead in its fuel. Semi-Synthetic oils have proven very effective in aviation engines that use lead. IF you want more info, I recommend using Google and spending a little time reading what you find.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-26-2012, 05:37 PM
TSwezey TSwezey is offline
I used Mobil 1. I used car gas most of the time and 100LL not to often.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 08-26-2012, 06:16 PM
These class action suits make for interesting reading. The question is, will a synthetic oil operated in an auto-conversion engine burning 93 octane pump gas present a problem. And lets say that 30% of the time the only fuel available is 100LL. Are you still going to have the sludge problem? Is the problem related in the class action suit due to the fact that certified aircraft engines are rather loose (sloppy?) in the tolerance department and the result is much more contamination in the case? Auto engines are built to much closer tolerances and I would think this would abate the sludge issue to a certain degree.
Aeroshell 15-50 is a semi-synthetic blend. What is the ratio? Is it 10% synthetic, 20%, more, less? All the auto oil brands have syn-blends as well. I would be curious to know the ratio.
Old 08-26-2012, 06:20 PM
I have read somewhere it is 50% synthetic. Some people blame AS 15W50 for Lycoming's epidemic of cam failures.
Byron
1977 Mooney 201
Houston, TX
Old 08-26-2012, 07:16 PM
RV6_flyer's Avatar
I am not willing to risk my safety trying to find out.
Some people like to do dangerous things. I will not risk my life, money, or time going down that path.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
