Old 08-19-2012, 04:03 PM
s10sakota's Avatar
s10sakota s10sakota is offline
Default OH RATS!!
Ok...I just riveted all of the ribs to the spar on the right wing. Of course now I realized that every single rivet is installed backwards. The shop head is on the rib side
What do I do? Drill every one out? Leave it? Call Vans? Anyone else this stupid? What did you do?
Mark Pensenstadler
1962 Piper Cherokee 160
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
2019 KITFOX Super Sport
Old 08-19-2012, 04:06 PM
Mel's Avatar
Mel Mel is offline
The only time rivet direction is critical is when they are flush rivets.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-19-2012, 04:08 PM
newtech's Avatar
newtech newtech is offline
Build on. If this is your only oops you will be better than most of us.
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
Old 08-19-2012, 04:29 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default No worries
As others said build on. When you rivet your leading edge to the spar the shop heads will be on the rib side. When able the factory head should be on the thinner side but it is not always possible.
Build on................................................ ................
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 08-19-2012, 04:58 PM
s10sakota's Avatar
Oh thank goodness!! I can't imagine drilling all those rivets out. The manual does state which way to put them in. I should have referenced the manual again before I started riveting. I guess I just got too excited to actually rivet!
Oh well...I still have the left wing to do correctly!
Mark Pensenstadler
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
Old 08-19-2012, 06:31 PM
Michael White's Avatar
No, no, no Mark...you have to do both wings the same way or you'll end up with a "heavy wing" condition!
Smile, Mark...I'm just kidding.
Moose
VAF #136
Old 08-20-2012, 04:41 AM
Sig600 Sig600 is offline
Wait until you squeeze 30-40 rivets, then realize you forgot to actually attach the part you're supposed to be riveting on.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 08-20-2012, 04:49 AM
sstellarv10 sstellarv10 is offline
Been there, done that
Steve Stella
#40654 Finishing
N521RV reserved
Old 08-20-2012, 06:10 AM
JurgenRoeland JurgenRoeland is offline
Call Vans? (
I once had a similar question and made a bit of a fool of myself - only realising later of course - asking this to Vans Support. Just to fully reassure you, this was Ken's answer :
"Rivet direction, at least in round-head rivets, is usually a matter of builder
convenience and makes no structural difference.
Once the rivet has a head on each end, it isn't smart enough to know which one the factory made and which one you made."
Jurgen Roeland
RV7 builder Belgium
www.jursairplanefactory.com
Old 08-20-2012, 09:07 AM
s10sakota's Avatar
HAHA good answer!
Mark Pensenstadler
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
