Go Back   VAF Forums > The Never Ending Debate Section > Nosewheel vs. Tailwheel
Old 08-19-2012, 05:57 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
Default First flight, again: RV-7A morphed to RV-7
After 4 1/2 months, I finally was able to fly again, following my TW conversion.
It had taken much longer than I anticipated, due to a mismatch of the new gear leg to an older engine mount. Prior to 10/2004, the mounts were match drilled to the gear . Following 10/2004, all are jig match drilled to standarize the fit. My issue resulted in an extreme tow out in which I had to oversize drill the gear leg to correct the tow out. Also, the cowling had to be trimmed to remove 1/2" from the aft end which required a whole lot of re-aligning of the cowl & hinge.
It's great to be back flying again. I received my TW endorsement yesterday and will join the ranks of the TW group.
Most landings were uneventful, but I still need to work on the xwind landings.
Interesting in that I've noticed is that the main gear is bit noisy compared to the tricycle gear. I figure it's probably due to the mains being more forward and can be heard versus the tricylcle gear was under the wing.
But, I don't hear or feel any nose gear shimmy.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 08-19-2012, 06:03 PM
N941WR's Avatar
N941WR N941WR is offline
Just think, you won't have to worry about getting a flat NW!
Congrats on the endorsement and the conversion.
Don't worry about the X-wind thing. After you get comfortable with the TW, you won't even give cross winds a second thought.
Just don?t taxi into any trailers.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-19-2012, 06:14 PM
Thanks. Bill.
Looking forward to seeing you all again at TripleTree.
1190+ hours
2019 Donation Paid
Old 08-19-2012, 06:31 PM
N941WR's Avatar
Dan, I hope to make Triple Tree. It is a bit questionable right now between the DNC shutting down the Charlotte Airspace and my wife leaving that Saturday morning for a CE class in TX I'm not sure sure when or if I'll make it.
Bill R.
SC86 - Easley, SC
Old 08-19-2012, 06:38 PM
Congrats on pulling it off, Dan. It is no small accomplishment.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 08-19-2012, 07:13 PM
Thanks David. I remember discussing it with you almost 4 years ago about my interest in the change & asked for your advice at the time.
Best of luck to you with your 8.
1190+ hours
2019 Donation Paid
